No input jack support in current iMACs
Help for Audacity on macOS.
Jesse Smith
Post by Jesse Smith » Mon Nov 17, 2014 9:27 pm
My 6-year old iMAC had an input jack that, with a Male to Male Cable, let you record from playing an external audio player in to it, while the current iMacs don't have input jack support. Is there a way to input audio from an external recorder, directly into the iMac and Audacity other that by just playing it, which of course would also record background noise?
Re: No input jack support in current iMACs
Post by kozikowski » Mon Nov 17, 2014 9:32 pm
We were sorry to see Stereo Line-In vanish across the Mac line.
I use and like the Behringer UCA202 stereo SoundCard. It's good quality and generic and will easily connect to almost anything.
This is one with my stereo mixer.
http://www.kozco.com/tech/audacity/pix/ ... Lenovo.jpg
Other people make similar adapters.
Post by kozikowski » Mon Nov 17, 2014 9:35 pm
A note. Make sure your adapter says stereo in and out. The ICUSBAUDIO, for one example is Mono Mic-In only, not stereo.
http://www.walmart.com/ip/13214962?wmls ... 31&veh=sem
