Yes "tenfold reduction to the minimum attack/release times" gets my vote.steve wrote:It may not be quite as much as you want, and I'd certainly want other improvements eventually, but do you support a tenfold reduction to the minimum attack/release times? (that's what's on the table now).
Shorter minimum attack and release times for Compressor
Re: Shorter minimum attack and release times for Compressor
I think it's OK, but that is one reason why I would not want to go even smaller. You can try it yourself now - committed in r13631.Gale Andrews wrote:Will that make the slider harder to use at the current range?
