Compressor Noise Floor Question
Help for Audacity on macOS.
jimmyhosen
Operating System: Windows 7
Re: Compressor Noise Floor Question
Post by jimmyhosen » Mon Jun 15, 2015 8:18 pm
To follow or participate in a discussion regarding a possible change to the Audacity Manual's description of the Noise Floor feature, you can go here:
http://forum.audacityteam.org/viewtopic ... 50&t=85910
