HELP! NEWBIE CANNOT TURN OFF INTERNAL MIKE
harlen
Post by harlen » Sun Nov 16, 2014 6:38 pm
Hi
I have downloaded the latest Audacity to my Toshiba Satellite C660 (Win 7) Laptop
I can use Audacity OK on my Desktop. But on the laptop I can only record from the built-in mike!
I have uninstalled & reinstalled several times to no avail.
The options next to the Mike symbol are "microsoft soundmapper Input" & "Microphone Realtek High Definitio......"
I use the former but the latter option doesn't work either
In Preferences Devices microsoft soundmapper is selected but it makes NO difference!
Help!
Re: HELP! NEWBIE CANNOT TURN OFF INTERNAL MIKE
Post by kozikowski » Sun Nov 16, 2014 6:42 pm
What do you want to record?
harlen
Post by harlen » Mon Nov 17, 2014 9:19 am
You Tube sound ?
harlen
Post by harlen » Mon Nov 17, 2014 2:00 pm
Panic Over
For others.....I had to go into:- Control Panel/Sound/Recording/right click to "show disabled devices"........and enable "Stereo Mix"
Why Oh why is it sold this way?????
Trebor
Post by Trebor » Mon Nov 17, 2014 2:09 pm
harlen wrote:I have downloaded the latest Audacity to my Toshiba Satellite C660 (Win 7) Laptop
Some computers don't offer the "stereo mix" aka "what-u-hear" option in Windows recording devices, ( which is a way of recording what you can hear on the computer).
harlen wrote:The options next to the Mike symbol are "microsoft soundmapper Input" & "Microphone Realtek High Definitio......"I use the former but the latter option doesn't work either
If you don't have "stereo mix" or equivalent option on the windows recording devices, download the latest Audacity version, (currently version 2.0.6), and select Windows WASAPI as the "host" in Preferences [:Devices], and select "speakers" as the recording device ...
a method of recording what you hear on speakers.gif (14.38 KiB) Viewed 509 times
http://manual.audacityteam.org/o/man/[u ... on_windows[/u].html
waxcylinder
Post by waxcylinder » Mon Nov 17, 2014 3:27 pm
harlen wrote:Panic Over
To try to stop you, or make it harder for you, to record copyrighted material 8-)
But glad you got it sorted - another trick you could have used is to use (software) loopback as your Recording Device with your host set to WASAPI - see this page in the Manual: http://manual.audacityteam.org/o/man/de ... .html#host
