Noise Gate problem
PMichaud
Noise Gate problem
Post by PMichaud » Mon Nov 10, 2014 10:51 pm
My name is Patrick Michaud, and I do not have Noise Gate as one of my options under the "Effects" drop down menu. Do I need to download it? Or should it already be there? Either way - how do I get it onto my "Effects" menu so I can edit out breath noises in between talking?
Thanks,
Patrick
Re: Noise Gate problem
Post by steve » Tue Nov 11, 2014 1:26 am
There is a Noise Gate effect available here: http://wiki.audacityteam.org/wiki/Nyqui ... Noise_Gate
Instructions to install it are here: http://wiki.audacityteam.org/wiki/Downl ... ns#install
