Selection panel
Selection panel
Please, explain, how to remove letters "h", "m", "s" from the selection panel and keep only figures in audacity of the latest version, see photo.
- Attachments
- Часы.png (49.03 KiB) Viewed 540 times
Re: Selection panel
To change the format in time selection boxes, click on the little black downward pointing triangle on the right side of the track and select the format that you want.
The format that is currently selected in your image is "hours + minutes + seconds + milliseconds".
Re: Selection panel
I' ll try to make more precise. In the latest version, audacity-win-r13568-2.0.7-alpha-09-nov-14, there are English letters: h, m, s. In the previous version there were Russian letters: ч, м, с., see photo. How to return russian letters in this panel, habitual for me?
- Attachments
- Часы1.png (30.48 KiB) Viewed 534 times
- Quality Assurance
Re: Selection panel
Thanks for the report. Yes, please always state the exact version you see at Help > About Audacity... (see the pink panel at the top of this page).юра00 wrote:I' ll try to make more presice.
This seems to be a bug introduced since the previous build audacity-win-r13554-2.0.7-alpha-07-nov-14. It affects all languages I tried.юра00 wrote: In the latest version, audacity-win-r13568-2.0.7-alpha-09-nov-14, there are English letters: h, m, s. In the previous version there were Russian letters: ч, м, с., see photo. How to return russian letters in this panel, habitual for me?
It isn't anything to do with the new .po files introduced since then. The rename made an hour or so ago https://code.google.com/p/audacity/sour ... il?r=13571 doesn't make any difference.
We'll look into the cause.
Alpha builds may have bugs, as you would expect.
