No sound imputting
emjay_uk_2000
No sound imputting
Post by emjay_uk_2000 » Wed Nov 05, 2014 9:37 pm
Hello I'm using Audacity 2.0.5 and I'm trying to record links (for a radio show I do). Now usually it works fine - it has for the past year, but for some reason when I press record audacity doesn't pick up my voice (or any sound!). I'm desperate to record something and need help!
I can play audio files in Audacity fine - so has a wrong setting been clicked perhaps? I can add more details if needed.
Many thanks
Emjay
Re: No sound imputting
Post by kozikowski » Thu Nov 06, 2014 1:21 am
What kind of microphone do you have and how is it connected? The computer can have many different audio connections. One recent posting wondered why the microphone wasn't working when they had the CD player music selected.
Whatever you're using for a microphone and the setting in the Audacity Device toolbar have to match.
http://manual.audacityteam.org/o/man/de ... olbar.html
