Realise a plugin
Building and customizing Audacity from the source code.
lefau44
Realise a plugin
Post by lefau44 » Mon Nov 03, 2014 4:26 pm
I would like to make an Audacity plugin but I did not find manual or web site for the first steps.
Does exist any documentation to help me or some examples ?
Thanks
I'm working with Visual C++ (2008) on Windows
I build Audacity last version on SVN
Re: Realise a plugin
Post by steve » Mon Nov 03, 2014 5:17 pm
Audacity supports a number of different plug-in formats, including VST (mostly on Windows), LADSPA, AU (Mac OS X only) and Nyquist.
Of these, probably the easiest to write are "Nyquist" plug-ins.
Because Nyquist plug-ins are specifically for Audacity, we have quite a lot of information. See this post: http://forum.audacityteam.org/viewtopic ... 39&t=77214
lefau44
Post by lefau44 » Mon Nov 03, 2014 5:20 pm
I try to use Nyquist plugin but I think it will be not OK for import plugin ?
Post by steve » Mon Nov 03, 2014 5:26 pm
What do you mean by "import plugin"?
What are you wanting to do?
lefau44
Post by lefau44 » Mon Nov 03, 2014 5:32 pm
I have some data in file with a specific format and I would like to import in Audacity to analyse , modify ...
So I need plugin to import and then plugin to use data
Post by steve » Mon Nov 03, 2014 5:35 pm
lefau44 wrote:I have some data in file with a specific format
What is the format?
Is the format supported by FFmpeg?
lefau44
Post by lefau44 » Mon Nov 03, 2014 5:44 pm
This is not a standard format so I need to create a plugin to import what I need
Post by steve » Mon Nov 03, 2014 5:54 pm
Are you an accomplished C/C++ programmer?
You're not giving me much information to go on, but assuming that it audio format, probably the easiest way would be to add support for your non-standard format to FFmpeg, then build Audacity against your custom FFmpeg headers.
Alternatively you could try writing a "module" type plug-in. Unfortunately there is not much documentation about this, but there are a couple of example modules included in the Audacity source code. There is some information in the Audacity wiki (it may be a bit out of date as the API is still undergoing development):
http://wiki.audacityteam.org/wiki/Experimental_Modules
http://wiki.audacityteam.org/wiki/GUI_Plugins
Also see here for information relevant to developers: http://wiki.audacityteam.org/wiki/Categ ... Developers
lefau44
Post by lefau44 » Tue Nov 04, 2014 9:14 am
Thanks for your help.
Sorry about the description of my needs but it's a new professional project (so C++ programming is OK for me) and I have not a lot of informations so I try ta have informations about all sorts of plug in.
I will try to see all possibilities with Nyquist to begin
lefau44
Post by lefau44 » Tue Nov 04, 2014 4:01 pm
I compiled the "mod-null" module -> I get the DLL file but Audacity doesn't load it ... Where should be the file "mod-null.dll" : in Audacity.exe directory or in a subfolder ?
The others exemples need Visual 2012 so I can't use them.
