I've not used Ubuntu for a while, but if I recall correctly you can check if proprietary drivers are available with (something like):
System Settings > Software & Updates > Additional Drivers
Recording from sound card at wrong speed. 48 vs 44.1 MHz
Please state:
Please state:
Re: Recording from sound card at wrong speed. 48 vs 44.1 MHz
