ok I just want to make sure I understand how this works.
you have N with = fs/fo .
fs is sampling rate = 44100Hz
Fo is the note you want to play like 440hz
then you make an array of N sizes and full it up with random value between 0.5 and -0.5
then you outputs the array from 0 to N then after N you do this
output = the 1st value of Array and the second value of the Array / by 2 * 0.995
and you keep doing this until output is 0?
is that right ?
this is mt class :
Code: Select all
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using NAudio.Wave;
namespace test
class Guitar : WaveStream
public Guitar()
Frequency = 0;
n2 = 0;
n3 = 0;
n4 = 0;
rnd1 = new System.Random();
t = 0;
decay = 0.995;
public double Frequency { get; set; }
public double Amplitude { get; set; }
static int n2;
static int n3;
static int n4;
public long Bufferlength { get; set; }
private long position;
float[] X;
float[] temp;
public override long Length { get { return Bufferlength; } }
public override WaveFormat WaveFormat { get { return WaveFormat.CreateIeeeFloatWaveFormat(44100, 2); } }
Random rnd1;
static int t;
double decay;
public override long Position
get
// we'll just return the number of bytes read so far
return position;
set
position = value;
// buffer size is 52920 and so is sampleCount
// oddset is 0
public override int Read(byte[] buffer, int offset, int sampleCount)
// Bufferlength set to the min I want the sound to play for
int N = (int)(44100D / Frequency); // size of buffer for the karplus-strong algorithm
float sum;// temp holding place
// below only happens once
// it make the karplus-strong algorithm buffer
if (n2 == 0) // flag
X = new float[N];
temp = new float[N + 1];
for (int i = 0; i < N; i++)
X[i] = (float)(0.1 * rnd1.Next(-5, 5)) + (float)(0.5 * Math.Sin(i * Frequency * Math.PI / 44100D));// random number from -0.5 - 0.5
// X[i] = (float)(0.5 * Math.Sin(i * Frequency * Math.PI / 44100D));
n2 = 1; // flag
// karplus-strong algorithm low pass filer
for (int r = 0; r < sampleCount / 4; r++)
if (t == (N - 1))
t = 0;
n4 = 1;
if (n3 >= Bufferlength && t == 0)
// Dispose(); // stop playing
// return 0; // stop playing
if (n4 == 0)
sum = X[t];
temp[t] = sum;
else
sum = (float)(X[t] + ((temp[t] + temp[t + 1]) * 0.5 * decay));// low pass filter and decay factor of 0,996
temp[t] = sum;
t++; // counter this is a static counter
decay = decay - 0.00009;
// send sum to the butter that so it can be played later
byte[] bytes = BitConverter.GetBytes(sum);
buffer[r * 4 + 0] = bytes[0];
buffer[r * 4 + 1] = bytes[1];
buffer[r * 4 + 2] = bytes[2];
buffer[r * 4 + 3] = bytes[3];
n3++;
return sampleCount;// end of Read sound start playing now
it get to a point where the number in the buffer just repeat...
that is wrong right ?
