Add track display view to AUP
This read-only archive contains discussions from the Adding Feature forum.
New feature request may be posted to the Adding Feature forum.
Technical support is available via the Help forum.
Edgar
Forum Crew
Post by Edgar » Tue Oct 28, 2014 5:54 pm
On -devel
http://audacity.238276.n2.nabble.com/Fr ... 64569.html
Martyn asked:
it would be great if the view of each track (Waveform, Waveform (dB), Spectrogram, Spectrogram (logF), Pitch (EAC)) were saved to the project (AUP) file
It's only a couple lines of code:
Code: Select all
Index: src/WaveTrack.cpp
--- src/WaveTrack.cpp	(revision 13514)
+++ src/WaveTrack.cpp	(working copy)
@@ -1473,6 +1473,8 @@
                return false;
             mChannel = nValue;
+         else if (!wxStrcmp(attr, wxT("waveTrackDisplay")) && XMLValueChecker::IsGoodInt(strValue) && strValue.ToLong(&nValue))
+            mDisplay = nValue;
          else if (!wxStrcmp(attr, wxT("linked")) &&
             SetLinked(nValue != 0);
@@ -1553,6 +1555,7 @@
    xmlFile.WriteAttr(wxT("rate"), mRate);
    xmlFile.WriteAttr(wxT("gain"), (double)mGain);
    xmlFile.WriteAttr(wxT("pan"), (double)mPan);
+   xmlFile.WriteAttr(wxT("waveTrackDisplay"), GetDisplay());
    for (WaveClipList::compatibility_iterator it=GetClipIterator(); it; it=it->GetNext())
Patch attached:
trackDisplay2AUP.patch
(932 Bytes) Downloaded 58 times
-Edgar
running Audacity personally customized 2.0.6 daily in a professional audio studio
occasionally using current Audacity alpha for testing and support situations
64-bit Windows Pro 10
Re: Add track display view to AUP
Post by steve » Tue Oct 28, 2014 6:09 pm
Would it be worth making it a little longer so that the XML is clearer for humans? (example: display=Waveform_dB)
Edgar
Forum Crew
Post by Edgar » Tue Oct 28, 2014 6:53 pm
steve wrote:Would it be worth making it a little longer so that the XML is clearer for humans? (example: display=Waveform_dB)
Funny you should ask; that's the way I originally tried to code it. Unfortunately, the value is an enumerated type so we would need to:
1) add a global constant static array of wxStrings (which would need to be kept in step with the enumerated types);
2) write & read the value as a string, then convert into an enumerated type (ditto – keep in step).
This adds a lot of complexity to what is otherwise trivially simple code.
One possible option would be to add a "NOOP" XML Tag when we write the track. Once again this would require that global constant static array of strings which would need to be kept in step with the enumerated types.
Code: Select all
<?xml version="1.0" standalone="no" ?>
<!DOCTYPE project PUBLIC "-//audacityproject-1.3.0//DTD//EN" "http://audacityteam.org/xml/audacityproject-1.3.0.dtd" >
<project xmlns="http://audacityteam.org/xml/" projname="Delta_data" version="1.3.0" audacityversion="2.0.1" sel0="0.0000000000" sel1="5.0000000000" vpos="0" h="0.0000000000" zoom="348.4000000000" rate="44100.0">
	<tags/>
	<wavetrack name="Audio Track" channel="2" linked="0" mute="0" solo="0" height="150" minimized="0" rate="44100" gain="1.0" pan="0.0" waveTrackDisplay="0" trackDisplaysAs="Waveform_dB">
		<waveclip offset="0.00000000">
			<sequence maxsamples="262144" sampleformat="262159" numsamples="220500">
				<waveblock start="0">
					<simpleblockfile filename="e0000c3f.au" len="220500" min="-0.799729" max="0.799916" rms="0.319909"/>
				</waveblock>
			</sequence>
			<envelope numpoints="0"/>
		</waveclip>
	</wavetrack>
</project>
The only problem here is keeping the string array in step with the enumerated types; we already have at least one similar problem in the TimeTextControl code where it is dealt with by a comment in the code.
I'd be happy to write a patch either way (or both ways) if you would like.
-Edgar
Post by steve » Tue Oct 28, 2014 7:04 pm
Edgar wrote:which would need to be kept in step with the enumerated types
1) What would happen with your original code if a later version of Audacity changed the enumerated types (so they were not in step with previous versions) and a user opens an old project?
2) What would happen if strings were used and a later version changed the strings?
My guess is that in the first case, the user will get the wrong waveform views (which could appear "random"). The integer values would be interpreted as unintended types.
In the second case, my guess is that any non-matching strings would be silently ignored, giving the default "Waveform" view for that track.
Edgar
Forum Crew
Post by Edgar » Tue Oct 28, 2014 9:00 pm
steve wrote: 1) What would happen with your original code if a later version of Audacity changed the enumerated types (so they were not in step with previous versions) and a user opens an old project?
In the first case your guess is partially right based on how the enumerated types were changed; if new types were simply added on the end than the old enumerated types would still be valid and should work. The opposite is not true, opening a newer project in an older version could cause grief.
In your second case your guess is correct (assuming that the Developers properly initialized the Track class' member for display type).
I suppose a sanity check should be added to ensure that, however the integer display type is calculated from the XML file, it is within the bounds of the enumeration type. I do not know if enumerations have a method to determine if a given value is a member of the enumeration or if that would need to be handrolled.
-Edgar
Post by steve » Tue Oct 28, 2014 9:39 pm
Edgar wrote:In the first case your guess is partially right based on how the enumerated types were changed;
In the example: "so they were not in step with previous versions"
In other words, not just adding a new one, but jumbling them up to some degree.
Edgar wrote:I suppose a sanity check should be added to ensure that, however the integer display type is calculated from the XML file, it is within the bounds of the enumeration type. I do not know if enumerations have a method to determine if a given value is a member of the enumeration or if that would need to be handrolled.
From a quick test with the current release version of Audacity:
  • Unrecognised attributes are ignored
  • Attribute values are always quoted strings ("NmTokens")
  • Handling / validating attribute values is handled in the Audacity code
What I'm suggesting, is that we use meaningful NmTokens rather than a zero indexed list of values (which still have to be written as quoted string values). Maintaining the list should be trivial as long as both the track view enumeration list and the associated NmToken string list are kept together somewhere sensible in the code.
(just a thought; if someone thoughtlessly changed from a zero indexed list to "one indexed", that would really screw things up ;))
I would be inclined to use an attribute rather than an element for this because:
1) It's not part of the project "data" (nothing to do with the actual audio)
2) There can only ever be one value per track (in the current track panel). XML allows multiple elements per tag but only one value per attribute.
3) XML (in Audacity) is robust against "foreign" attributes, whereas foreign elements can invalidate the entire tag (or entire project).
4) Maintaining backward and future compatibility is probably easier.
Edgar
Forum Crew
Post by Edgar » Tue Oct 28, 2014 9:42 pm
Sanity check (after applying the previous patch):
In srcWaveTrack.h at or near line number 391 we need to change the enumeration slightly and add a new function:
Code: Select all
enum WaveTrackDisplay {
      WaveformDisplay,
      WaveformDBDisplay,
      SpectrumDisplay,
      SpectrumLogDisplay,
      PitchDisplay
   const static bool ItIsAMemberOfWaveTrackDisplay(WaveTrackDisplay pDisplayType) {
      if ((pDisplayType == WaveformDisplay) ||
         (pDisplayType == WaveformDBDisplay) ||
         (pDisplayType == SpectrumDisplay) ||
         (pDisplayType == SpectrumLogDisplay) ||
         (pDisplayType == PitchDisplay)) return true;
      return false;
and use the function for a sanity check in srcWaveTrack.cpp at or near line number 1476:
Code: Select all
         else if (!wxStrcmp(attr, wxT("waveTrackDisplay")) && XMLValueChecker::IsGoodInt(strValue) && strValue.ToLong(&nValue)) {
            if (ItIsAMemberOfWaveTrackDisplay(((WaveTrackDisplay)nValue)))
               mDisplay = nValue;
            else mDisplay = WaveformDisplay;
*Edit – 28 October 2014: error in sanity check code
-Edgar
Edgar
Forum Crew
Post by Edgar » Tue Oct 28, 2014 10:02 pm
In short - chaos!
steve wrote: From a quick test with the current release version of Audacity:
Unrecognized attributes are ignored - yes.
Attribute values are written as strings, but in this case they are converted from integers and then back into integers and there is no (easy) way for the Write/Read code to convert from the enumerated integer into a string. It could be done but as I pointed out above it would require duplicating the integer enumeration with a string array (both of these declarations/definitions must be in the header file WaveTrack.h). Then you would have to have, in both the XML Write & XML Read functions, a complex set of if/else if statements stepping through all of the possible strings (obviously, this would need to be in WaveTrack.cpp). These two sets of complex if/else if statements would need to be kept in step with the declarations (both of which would need to be kept in step with each other) in the header file. In short ugly and not something I would want to try to get past Developer review.
-Edgar
Edgar
Forum Crew
Post by Edgar » Tue Oct 28, 2014 10:11 pm
steve wrote: I would be inclined to use an attribute rather than an element for this because:
Code: Select all
void WaveTrack::WriteXML(XMLWriter &xmlFile)
   xmlFile.StartTag(wxT("wavetrack"));
   xmlFile.WriteAttr(wxT("name"), mName);
   xmlFile.WriteAttr(wxT("channel"), mChannel);
   xmlFile.WriteAttr(wxT("linked"), mLinked);
   xmlFile.WriteAttr(wxT("mute"), mMute);
   xmlFile.WriteAttr(wxT("solo"), mSolo);
   xmlFile.WriteAttr(wxT("height"), this->GetActualHeight());
   xmlFile.WriteAttr(wxT("minimized"), this->GetMinimized());
      it->GetData()->WriteXML(xmlFile);
   xmlFile.EndTag(wxT("wavetrack"));
In respect to WaveTracks I do not understand your distinction between "attribute" & "element"; the above is the complete XML Write function for the WaveTrack. I do not really understand all this XML code but from what you are saying I think you mean that we should add a new "sub tag" under the basic "wavetrack" (xmlFile.StartTag(wxT("wavetrack"));), give it a human readable name and no elements. I suppose I could try this but all of the previous complaints about complex if/else if still apply.
-Edgar
Post by steve » Tue Oct 28, 2014 11:16 pm
Edgar wrote:In respect to WaveTracks I do not understand your distinction between "attribute" & "element";
I'm looking at this from the AUP file (XML) point of view.
Currently we have a structure like:
Code: Select all
<wavetrack name="Audio Track" channel="2" linked="0" mute="0" solo="0" height="150" minimized="0" isSelected="1" rate="44100" gain="1.0" pan="0.0">
    <sequence maxsamples="262144" sampleformat="262159" numsamples="1323000">
        <simpleblockfile filename="e00002b4.au" len="262144" min="-0.799917" max="0.799982" rms="0.517421"/>
      </waveblock>
      <waveblock start="262144">
        <simpleblockfile filename="e000047d.au" len="262144" min="-0.661273" max="0.661167" rms="0.419531"/>
      </waveblock>
      <waveblock start="524288">
        <simpleblockfile filename="e00002ac.au" len="262144" min="-0.522573" max="0.522572" rms="0.32174"/>
      </waveblock>
      <waveblock start="786432">
        <simpleblockfile filename="e000063a.au" len="262144" min="-0.383848" max="0.383812" rms="0.224217"/>
      </waveblock>
      <waveblock start="1048576">
        <simpleblockfile filename="e00006c5.au" len="262144" min="-0.245159" max="0.245132" rms="0.127524"/>
      </waveblock>
      <waveblock start="1310720">
        <simpleblockfile filename="e00002fd.au" len="12280" min="-0.106462" max="0.106465" rms="0.031621"/>
      </waveblock>
    </sequence>
  </waveclip>
</wavetrack>
Simplified:
Code: Select all
<wavetrack attribute="value" ... >
	<waveclip offset="value">
		<sequence attributes="values" ...>
				<simpleblockfile attributes="values" ... />
			</waveblock>
		</sequence>
	</waveclip>
</wavetrack>
To add "WaveTrackDisplay" as an element (child element):
Code: Select all
	<spectrumdisplay>
				</waveblock>
			</sequence>
		</waveclip>
	</spectrumdisplay>
</wavetrack>
As an attribute of the <wavetrack> element:
Code: Select all
<wavetrack name="Audio Track" WaveTrackDisplay="SpectrumDisplay" channel="2" linked="0" mute="0" solo="0" height="150" minimized="0" isSelected="1" rate="44100" gain="1.0" pan="0.0">
