Remove unused/obsolete variable ETBZoomToggleID
Building and customizing Audacity from the source code.
Edgar
Forum Crew
Post by Edgar » Mon Oct 27, 2014 12:59 am
Commit r5548
Author: lll
Date: 15 September 2006
5548 llucius #if 0 // Disabled for version 1.2.0 since it doesn't work quite right...
5548 llucius ETBZoomToggleID,
5548 llucius #endif
ETBZoomToggleID only appears in three lines of code all of which have been disabled since 2006. I suspect these lines could be removed. I will attach a patch but it will probably be stale quickly.
Code: Select all
Index: src/toolbars/EditToolBar.cpp
--- src/toolbars/EditToolBar.cpp	(revision 13509)
+++ src/toolbars/EditToolBar.cpp	(working copy)
@@ -260,13 +260,6 @@
       case ETBZoomOutID:
          p->OnZoomOut();
          break;
-#if 0 // Disabled for version 1.2.0 since it doesn't work quite right...
-      case ETBZoomToggleID:
-         p->OnZoomToggle();
-         break;
-#endif
       case ETBZoomSelID:
          p->OnZoomSel();
          break;
@@ -311,10 +304,6 @@
    mButtons[ETBZoomInID]->SetEnabled(tracks && (p->GetZoom() < gMaxZoom));
    mButtons[ETBZoomOutID]->SetEnabled(tracks && (p->GetZoom() > gMinZoom) );
-   #if 0 // Disabled for version 1.2.0 since it doesn't work quite right...
-   mButtons[ETBZoomToggleID]->SetEnabled(tracks);
-   #endif
    mButtons[ETBZoomSelID]->SetEnabled(selection);
    mButtons[ETBZoomFitID]->SetEnabled(tracks);
Index: src/toolbars/EditToolBar.h
--- src/toolbars/EditToolBar.h	(revision 13509)
+++ src/toolbars/EditToolBar.h	(working copy)
@@ -43,11 +43,6 @@
    ETBZoomInID,
    ETBZoomOutID,
-   ETBZoomToggleID,
-   #endif
    ETBZoomSelID,
    ETBZoomFitID,
ETBZoomToggleID.patch
(1.32 KiB) Downloaded 90 times
-Edgar
running Audacity personally customized 2.0.6 daily in a professional audio studio
occasionally using current Audacity alpha for testing and support situations
64-bit Windows Pro 10
