Remove EXPERIMENTAL designation from sync lock
Building and customizing Audacity from the source code.
Edgar
Forum Crew
Post by Edgar » Mon Oct 27, 2014 12:52 am
SVN Blame says:
Commit r10674
Author: windinthew
Date: Sep 14, 2010
EXPERIMENTAL_LINKING -> EXPERIMENTAL_SYNC_LOCK to match with r10673
Sync Lock was turned on over four years ago and has not been changed to OFF since then. I contend that it is no longer "experimental" and that it should be removed from Experimental.h and a few files associated with the #define.
Patch attached.
SyncLockNoLongerExperimental.patch
(6.02 KiB) Downloaded 96 times
