mandolin sound [SOLVED]
suttlemyre
Post by suttlemyre » Sat Oct 25, 2014 7:46 pm
what would you suggest as a close mandolin sound( taken from a guitar track) I have sent a sample piece.
sample.mp3
(395.97 KiB) Downloaded 87 times
Re: mandolin sound
Post by kozikowski » Sun Oct 26, 2014 1:49 am
I'm not sure I get this. It sounds like a big-body guitar to me. Is this part of another posting?
Trebor
Re: mandolin sound
Post by Trebor » Sun Oct 26, 2014 7:13 am
suttlemyre wrote:what would you suggest as a close mandolin sound( taken from a guitar track) I have sent a sample piece. Attachments sample.mp3 (395.97 KiB)
You wanted a guitar+mandolin combo.
Duplicate the guitar track , (press Ctrl + D).
Apply "Sliding time scale/ pitch shift" , (in "Effects" menu), with settings shown to the duplicated guitar track.
window-Time Scale-000.png (8.43 KiB) Viewed 657 times
Voila you have guitar and mandolin (ish) ...
before-after mandolinization.mp3
guitar (before) , then guitar+mandolin
(646.53 KiB) Downloaded 82 times
Applying some randomization to the amplitude and timing would make it sound more like two humans playing,
there are two plugins which randomize ...
http://wiki.audacityteam.org/wiki/Nyqui ... Modulation
http://wiki.audacityteam.org/wiki/Nyqui ... Modulation *
[ * Random_Pitch_Modulation applied to a stereo track makes the instrument wander about in the stereo field ].
Robert J. H.
Re: mandolin sound
Post by Robert J. H. » Sun Oct 26, 2014 7:17 am
kozikowski wrote:I'm not sure I get this. It sounds like a big-body guitar to me. Is this part of another posting?
He only wants to know what kind of mandolin sound one could super-impose on that riff.
I would probably just double the melody on the treble strings and play with the fingers.
However, Nyquist (the built-in sound language) provides a mandolin-model as well.
The following code for the Nyquist prompt (effect menu, with a duplicate of the guitar selected) produces a straight randomized melody around D major (listen to the attached file)
Code: Select all
(setf indiv-dur (/ (1- (get-duration 1)) 32.0))
(setf notes '(a3 d3 a4 d4 fs4 g4 a4 d5 fs5 g5 a5 d6 e6 fs6))
(extract 0 1
   (scale-db -15
      (simrep (i 32)
         (prog2 (setf current
            (eval (nth (truncate (real-random 0 (length notes))) notes)))
            (scale (real-random 0.1 1.0)(at-abs   (* i indiv-dur)  (mandolin current 1.0 3)))))))
The dual-mono track is furthermore treated with the random-pitch modulation plug-in from the Wiki with a depth of 0.01 to give more spaceness and less artificial character.
mandolin_sample.mp3
(217.52 KiB) Downloaded 66 times
It is clear that writing a whole song is labour-intensive in that fashion.
suttlemyre
Re: mandolin sound
Post by suttlemyre » Sun Oct 26, 2014 3:40 pm
that is what I was looking for thanks
