A lot of work was done a couple of weeks ago to make the entire Audacity code compile and run under wxWidgets3. This means that it is especially important that any new code that gets added be tested to ensure that it compiles and runs under wxWidgets3 & wxWidgets2. My previous warning was because I posted the patch while all four configurations were building but only the first two (wxWidgets3) had finished <grin-twiddling thumbs>.steve wrote:No not yet. There has been some exploratory work, but there is currently a lot of other stuff going on, so Audacity is officially remaining with WxWidgets 2.8 for the next release.Robert J. H. wrote:Have we already switched to WXW3.02?
Display label count
Re: Display label count
-Edgar
running Audacity personally customized 2.0.6 daily in a professional audio studio
occasionally using current Audacity alpha for testing and support situations
64-bit Windows Pro 10
Robert J. H. wrote:I somehow feel that the description should really defined in TrackPanelAx.Edgar wrote:I have made a first tab at TrackInfoAx
The "GetDescription" method would be still helpful to display the Label counts.
By the way, NVDA is free and comes with the necessary tools to debug your patches.
I can of course perform the testing part, the latency will be terrible though.
Code: Select all
TrackInfo code is destined to move out of this file.
Code should become a lot cleaner when we have sizers.
**********************************************************************/If we can get the GetDescription function working that I will see how to create a new function GetLabelCounts and move the functionality into that.
I once installed NVDA to do some testing with Audacity but, as I recall, it conflicted horribly with Dragon NaturallySpeaking which I use to control my computer (I'm seriously restricted in my ability to use the keyboard and to a lesser extent the mouse). I have no problem with latency – I have a good latency correction tool (a good book to read).
-Edgar
