Audacity doesn't launch! [SOLVED]
юра00
Post by юра00 » Thu Oct 16, 2014 10:27 am
audacity-win-r13444-2.0.7-alpha-16-oct-14-wx3.0.2
After extracting from archive and attempt launching appears ( look an attached file):
Please, explain, how can I launch the program in such case? Windows 8.1
Re: Audacity doesn't launch!
Post by Gale Andrews » Thu Oct 16, 2014 10:56 am
Thanks for the report.
Please go back to http://gaclrecords.org.uk/win-nightly/ and install the VS2013 redistributables linked to there.
юра00
Re: Audacity doesn't launch! [SOLVED]
Post by юра00 » Thu Oct 16, 2014 2:11 pm
Thank you! Now audacity-win-r13444-2.0.7-alpha-16-oct-14-wx3.0.2 is launching successfully!
Post by Gale Andrews » Thu Oct 16, 2014 2:37 pm
You're welcome. I've locked this topic now as it is solved, but note that the version you downloaded is built with a new version of wxWidgets (3.0.2).
If you see anything different or incorrect in the Audacity interface, please let us know in a new topic.
I've already noticed that the "Save Changes?" dialogue has lost its "Question mark" icon in the new build.
