Task Scheduler no longer talks to Audacity
Edgar
Forum Crew
Re: Task Scheduler no longer talks to Audacity
Post by Edgar » Tue Oct 21, 2014 7:12 pm
Emerogork2 wrote:You comment that I don't need to reset to the beginning and to mute however are they doing any harm?
Now that I see the full scope of what you are doing these do make sense and do no harm.
I think you should make a copy of your Audacity configuration file, remove all but the one line in your current configuration file so that it is simply initializedif you need help with these topics look here:
http://manual.audacityteam.org/o/man/pr ... tml#stored
http://manual.audacityteam.org/o/man/pr ... html#reset
Then uninstall 2.0.6, reinstall 2.0.5 and try again. If this makes everything work as it was before we can discuss your options.
Reason: fixed Manual links to point to released Manual
