Wav file is static
Gunnar
Re: Wav file is static
Post by Gunnar » Sat Oct 11, 2014 1:56 pm
johnnyc2016 wrote:Format : Wave
Codec ID : A119
0xA119 does not seem to be among the WAVE Codec ID's that FFmpeg does recognize (see link in this post). How did to create that file or where did you obtain it?
EDIT: Could be the ATRAC3plus format, a format use primarily on "MiniDisc".
steve wrote:The "Codec ID" that MediaInfo gives for a normal WAV file is "1".
Actually I would say that there are no "normal" and "abnormal" WAVE files.
WAVE is a container that can store a multitude of different audio formats. Uncompressed PCM is only one of them and even plain PCM can be either 0x1 (Integer) or 0x3 (floating point). See this post for details.
Post by steve » Sat Oct 11, 2014 4:35 pm
Gunnar wrote:Actually I would say that there are no "normal" and "abnormal" WAVE files.
By far the most common type of WAV file is "signed 16 bit PCM". As it is far more common than other types of WAV, I don't think it is unreasonable, when describing in layman's terms, to refer to it as "normal" ;)
Post by Gale Andrews » Sat Oct 11, 2014 5:12 pm
Gunnar wrote:Could be the ATRAC3plus format, a format use primarily on "MiniDisc".
It seems unlikely - that has a fixed minimum 48 kbps bit rate and I doubt Media Player would play it.
