Lenco
vandevyvere
Lenco
Post by vandevyvere » Thu Jan 08, 2009 7:57 pm
Hello,
I have bought a Lenco turntable.
So it's possible with the usb-cable to connect to a computer.
But I have an Imac computer by Apple.
Does anyone knows if the software of this turntable is working on Apple computers ?
Because on the disc who has been delivered with, they are speaking of Windows Vista en XP but not about Max Os X.
So please inform.
Thanks in advance.
Best regards,
Peter Vandevyvere
Re: Lenco
Post by kozikowski » Thu Jan 08, 2009 8:40 pm
The USB connection on many turntables causes problems. You have a Mac, so you can easily use the analog output of the turntable and the analog input of the Mac. See in the turntable instructions how to deliver Line-Level sound. Connect that to the iMac Line-In which is the small circle with two black arrows pointing inside.
That cable is usually dual RCA connector one end to a single stereo 1/8" or 3.5 mm Stereo Plug ion the other end.
Kzo
vandevyvere
Re: Lenco
Post by vandevyvere » Sat Jan 10, 2009 4:29 pm
Hello,
Thanks for the information.
I will try.
Thanks a lot.
Best regards,
Peter
