DC Offset [SOLVED]
jimmyhosen
Operating System: Windows 7
DC Offset [SOLVED]
Post by jimmyhosen » Thu Oct 09, 2014 2:27 am
This effect would allow users to either:
  1. Automatically remove DC Offset
    Manually add DC Offset
The ability to add DC Offset enables users to apply some effects (e.g. hard limiting) to mostly/only the positive or negative side of the waveform, then return the waveform back to center.
Re: DC Offset
Post by steve » Thu Oct 09, 2014 2:37 am
See this topic: http://forum.audacityteam.org/viewtopic ... 96#p193996
Instructions for installing Nyquist plug-ins are here: http://wiki.audacityteam.org/wiki/Downl ... g_Plug-ins
jimmyhosen
Re: DC Offset
Post by jimmyhosen » Thu Oct 09, 2014 2:55 am
Hmmm... I did not see that effect listed on the following page, so I thought that it was not available...
http://wiki.audacityteam.org/wiki/Nyqui ... t_Plug-ins
Thank you for providing the link! Is this effect indeed missing from the list of Nyquist effects?
Re: DC Offset
Post by steve » Thu Oct 09, 2014 3:06 am
There are quite a few "unofficial" plug-in in this section of the forum: http://forum.audacityteam.org/viewforum.php?f=42
Many of them are "experimental" or not widely tested.
User feedback about plug-ins in that section of the forum is very helpful in deciding if a plug-in is "ready" for putting on the wiki.
Feel free to browse that forum board, and comment on any plug-ins that you try.
jimmyhosen
Re: DC Offset
Post by jimmyhosen » Thu Oct 09, 2014 3:20 am
1. I have installed the "DC offset" plugin and it works as advertised. :)
2. I am perusing that "New Plugins" area now...
3. Thank you! You gave incredibly quick and helpful replies!
