I've tried to built the newest version 2.0.7 alpha.
Audacity.sln is no longer a valid VS 2008 solution.
It seems that the developers have decided to migrate to VS 2013.
However, it would have been nice if this were announced e.g. in this forum and when the compile.txt's would have been adapted accordingly.
From the Audacity.sln file is not readily apparent which VS should be installed--it has as header:
Thus, I've installed MS VSE2012--which does not work because it assumes Version 4.0 of MSBuild.exe.Microsoft Visual Studio Solution File, Format Version 12.00
# Visual Studio Express 2012 for Windows Desktop
Although the msbuild.exe 12.0 can be downloaded separately, it still won't build the solution. Btw, VS2012 is hardly accessible which makes it even worse to detect the problem.
The revision comments suggest (at Rev 13401) that VS 2013 should be used and that an obsolete Audacity solution remains for the time being.
However, former is for Windows 8.1 and latter produces a bunch of errors in VSE 2008.
Will there any proper guide lines be available in the near future how to scope with this migration?
Regards
RJ
