Audacity 1.2.x and 1.3.x are obsolete and no longer supported. If you still have those versions, please upgrade at
https://www.audacityteam.org/download/.
The old forums for those versions are now closed, but you can still read the archives of the
1.2.x and
1.3.x forums.
waxcylinder
Post
by waxcylinder » Tue Oct 07, 2014 9:10 am
Emerogork wrote: ... I am sure this would be easier to diagnose if I could induce the problem with some predictability....
Yup indeed - the developers/QA have the same problem too - there are a few bugs listed for Audacity which are tagged as "moonphase" as they occur only with certain phases of the moon and alignments of the planets
Their wretched unpredictability makes them tough nuts for the devs to crack
