adjusting sound levels for all .wav files
Re: adjudting sound levels for all .wav files
Post by steve » Sun Oct 12, 2014 6:43 pm
Gunnar wrote:I don't know how this could be made any clearer.
The only thing that made it unclear for me was your additional license text (in addition to the standard license text) that appeared when I first loaded the VST version in Audacity, stating "some rights reserved".
Gunnar
Post by Gunnar » Sun Oct 12, 2014 7:00 pm
steve wrote:It does not seem to be audible with real-world audio, but this image is a generated "440 Hz sine tone. 30 seconds duration, amplitude 0.8" to which I have applied the VST version with the default settings. Zooming in shows small, but clearly visible 500 ms "steps" as the amplitude is ramped up.
I was able to reproduce this behavior. I think I have tracked down what caused this and a fix is on the way...
I think everything about that has been said:
Gunnar wrote:BTW: You will often find the line "All rights reserved" in copyright notices. That's because this line was required in copyright notices in the past. Without that line it was not possible (or at least more difficult) to enforce the author's rights, e.g. to sue somebody who violates the license terms. Today, as far as I know, this line is no longer necessary, in most countries. Anyhow, I tend to keep the variant "Some rights reserved" to make clear that this software is OpenSource but not "public domain" (that is: it's "free software" but that does not mean you do whatever you want with it). The restrictions and obligations of the respective software license, e.g. GPL or LPGL, apply.
Gunnar wrote:If the original author didn't reserve at last some rights, then the software would effectively become "public domain". And then some company could come along and incorporate that software into their commercial products without ever telling anybody or without ever giving back anything. And that even would be perfectly legal, since the code is "public domain". Thus, if you wish that the (L)GPL applies to your work, you have to reserve some rights...
Gunnar
Post by Gunnar » Sun Oct 12, 2014 9:07 pm
Robert J. H. wrote:Although this smoothing is applied, the plug-in seems to have a steppy response.
The Gaussian kernel is applied on the "per frame" gain factors, so that the gain factors of neighboring frames will be smoothed. However, since each frame will still get its own separate gain factor, we can not (or better: should not) simply apply a frame's gain factor to all samples inside that frame - that would result in an ugly discontinuity at the frame boundary! Consequently, the "per sample" gain factors inside of each frame will be interpolated, from the previous frame's gain factor to the current frame's gain factor, so that we get a steady transition rather than "jumps" at the frame boundary. It was a small bug in that interpolation code which caused that "steppy response" you were seeing :oops:
Please try with the new version here:
https://mega.co.nz/#!ERUU1TxL!IA_pV90FA ... BCfxCJYH9c
Post by Gale Andrews » Mon Oct 13, 2014 8:37 am
Gunnar wrote:
steve wrote:Does your software have license restrictions that go beyond (ie more restrictive than) the respective LGPL/GPL/MIT licenses or is your software under standard LGPL/GPL/MIT licenses?
Nope.
Then IMO you don't need extra words in the licence. It's already implicit in the licence that you retain all copyright.
QT look as if they have separate versions of the software under different licences. If so they are not mixing and matching licences for the same version.
You can incorporate GPL code in a commercial closed source product without licensing the commercial product under GPL. For example it can be done by loading the open source code as a plug-in within the commercial product.
Gunnar
Post by Gunnar » Mon Oct 13, 2014 12:30 pm
Gale Andrews wrote:Then IMO you don't need extra words in the licence. It's already implicit in the licence that you retain all copyright.
As mentioned before, the line may not be absolutely required nowadays in most countries, but it doesn't hurt either and makes things more clear (though that doesn't seem to be the case here).
If the copyright holder of a software wants that his/her software can be used (only) under a specific license, e.g. the GPL or LGPL, the copyrights must necessarily remain at the copyright holder, so that the license can actually be enforced. Otherwise, if the copyright holder decides to give up his rights, the software becomes "public domain" and everybody can do whatever he or she wants with the software - regardless of any software license restrictions!
Gale Andrews wrote:Then IMO you don't need extra words in the licence. It's already implicit in the licence that you retain all copyright.You can incorporate GPL code in a commercial closed source product without licensing the commercial product under GPL. For example it can be done by loading the open source code as a plug-in within the commercial product.
Nope. That is allowed with the LGPL, but not with the GPL.
If a proprietary ClosedSource application loads a DLL or ShareObject (at runtime) that was released under the LGPL (not GPL), then this is considered a "use of the work", but not creating a "derivate work". Thus, the code of the main application can remain under whatever proprietary license it was before, in this case. But with the GPL (not LGPL) it doesn't matter whether you insert the code as "copy & paste", link it as a "static" library or load it as a DLL/ShareObject at runtime - in any of these cases you are creating a "derivate work" and thus your own code must be distributed under the GPL too. I'm not a lawyer either, but that's how the GPL and LGPL are commonly interpreted :geek:
BTW: You can still ship a GPL'ed application along with a proprietary CloseSource one, as long as they remain two separate stand-alone programs. And as long as the sources for the GPL'ed application are made available.
Gale Andrews wrote:QT look as if they have separate versions of the software under different licences. If so they are not mixing and matching licences for the same version.
Nope. Starting with Version 4.5 the Qt Framework uses a LGPL/Commercial dual license model. The Qt Framework is released under the LGPL and, at the same time, under some proprietary commercial license. The code is exactly the same with both licenses, though the "commercial" license may include access to some bonus tools that I'm not aware of (never used the "commercial" license, because I never needed it).
That is: As long as your application is OpenSource or as long as your ClosedSource application uses an unmodified Qt Framework as DLLs (SharedObjects), you can use Qt under the LGPL. If, however, you wish to link Qt statically into your ClosedSource application or if you modified the Qt Framework (and don't want to publish your modifications), then you have to buy the commercial license.
At all times, Qt was available under a commercial license that allows developing proprietary applications with no restrictions on licensing. In addition, Qt has been gradually made available under several increasingly free licenses. [...] Until version 1.45, source code for Qt was released under the FreeQt license. [...] With the release of version 2.0 of the toolkit, the license was changed to the Q Public License (QPL). [...] In 2000, Qt/X11 2.2 was released under the GPL v2 [...] This was resolved when Trolltech released Qt/Windows 4 under the GPL in June 2005. Qt 4 now supports the same set of platforms in the free software/open source editions as in the proprietary edition, so it is now possible to create GPL-licensed free/open source applications using Qt on all supported platforms. [...] On 14 January 2009, Qt version 4.5 added another option, the LGPL. - Wikipedia
BTW: The x264 project uses a very similar dual license model, though they use GPL and commercial, rather than LGPL and commercial.
Post by steve » Mon Oct 13, 2014 1:28 pm
Gunnar wrote:but it doesn't hurt either and makes things more clear (though that doesn't seem to be the case here).
Of course you are entitled to license your work under whatever license you want, but as feedback (not criticism) from the standpoint of a user, I think the additional text makes it less clear (otherwise I'd not have mentioned it in the first place ;).
In particular, the license agreement that comes up on first use of the VST effect says that it is licensed under LGPL v2.1 or later.
That would have been clear to me if it were not that you have added the additional text, which suggested to me that there may be additional restrictions, which is confirmed by the fact that if I don't click the OK button to "agree", then I can't use the software, though LGPL v 2.1 does not require that the user accepts the terms in order to "use" the software. Section 9 of LGPL v2.1 makes it clear that acceptance of the license agreement is required "for copying, distributing or modifying the Library or works based on it" but places no such restriction on "using" the software. As this restriction on use is contrary to the freedom granted by the stated license, that would appear to invalidate the agreement. So no, I don't think it is clear.
Gunnar
Post by Gunnar » Mon Oct 13, 2014 2:28 pm
First of all, I don't think the Copyright notice (may the "All rights reserved" line still be needed nowadays in your/my country or not) is not "contrary" to the license terms at all. Instead, it's a necessary precondition for the license to be applied. If the original author didn't retain the rights on his software, he or she wouldn't be in the position to license the software to anybody - and thus any license terms would be void.
Secondly, the "license" dialog box is more of an informational nature. It informs the user which license applies to the software and, even more important (from the author's point of view), that the software comes "WITHOUT ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE". If the user isn't okay with that, he should click "Cancel" an not use the software. At least, if the software destroys your computer and kills your cat, you cannot say that you haven't been warned. And it's the exactly same notice that the (L)GPL suggests adding to your software! A console application would usually print this notice to the console on application startup (or when a special "--license" switch is used), while a GUI application would show it in its "About" dialog. Neither method is applicable to a VST plug-in, so it has been implemented as a pop-up dialog that appears on the first use.
Post by steve » Mon Oct 13, 2014 3:08 pm
Gunnar wrote: I don't think the Copyright notice ..<snip>.. is not "contrary" to the license terms at all.
I didn't say it was. I said that requiring acceptance of the license for "use" of the software imposes a restriction on the user over and above that which is stated in LGPL v.2.1. In other words, it is restricting the end users freedom to a greater degree than the LGPL v.2.1 license.
Gunnar wrote:If the original author didn't retain the rights on his software, he or she wouldn't be in the position to license the software to anybody - and thus any license terms would be void.
Of course if the GPL/LGPL licenses did not already cover that, then those licenses would be meaningless, but they do clearly state what rights each party has and what rights they do not have. That is the point of the license. If you are not happy with the terms of the license that you are using then you should use a different license.
I have no vested interest in whatever license you chose to use, and that is entirely your right and your decision. but imho if you declare that it is released under LGPL v2.1 then it should be exactly those terms that apply, no more and no less (otherwise it is not really LGPL v2.1 is it?)
Gunnar wrote:At least, if the software destroys your computer and kills your cat, you cannot say that you haven't been warned.
:D
Post by Gale Andrews » Mon Oct 13, 2014 10:49 pm
I agree with Steve. It does not make things more clear. And for GPL you should not require acceptance at all.
Yes, that is what I meant - I should have explained further. FSF have told me that loading a GPL plug-in that displays a separate GPL licence inside a closed source app was permissible.
If the GPL plug-in loads without licence and so looks like part of the host application, it's probably not acceptable, unless the user had first to separately install the GPL application and see its licence, before it could be loaded in the closed source app.
Gunnar
Post by Gunnar » Tue Oct 14, 2014 12:05 am
Well, if some code that was released under the GPL is modified and/or combined with other code, this creates a "derivate work". And such "derivate work", as a whole, then needs to be distributed under the GPL. Whether the GPL'ed code is linked with the other code in the form of a (plug-in) DLL or as a static library or simply via copy&paste doesn't matter for the GPL. It's the LGPL that allows combining the LGPL'ed code with proprietary code - but only as long as the LGPL'ed portion and the proprietary portion of the software can still be linked separately. This is usually interpreted in the way that the LGPL'ed code must remain in a separate DLL, while linking it in as a "static" library is forbidden.
Anyway, you are allowed to load a GPL'ed plug-in into a proprietary application, because you are not redistributing anything at this moment. The GPL only requires you to publish the source codes, if you actually redistribute the software. That's also why you can modify a GPL'ed software and never publish your modified sources - as long as you never distribute your modified version. If you do distribute the modified version, the modified sources have to be published too.
