Corrupted titles of in/outs (2.0.6) on OS X w czech locales
Hi,
since Audacity 2.0.6 names/titles of Inputs and Output looks weird: Corrupted playback device name should be "Vestavěný výstup" (in System Preferences->Audio it is called "Interní reproduktory").
Corrupted recording device names should be "Vestavěný mikrofon" and "Vestavěný vstup" (in System Prefs->Audio they're called "Interní mikrofon" and "Linkový vstup").
OS X (10.9.5) localization is "Czech" (Audacity language selected english - but it doesn't affect these names).
In previous version of Audacity (2.0.5) these inputs/outputs was named in english (regardless of OS localization and/or Audacity language selection). It wasn't a problem, still better english than gibberish:
- Quality Assurance
Re: Corrupted titles of in/outs (2.0.6) on OS X w czech loca
Thanks for the report. Yes I can confirm that. I think this may have happened because for 2.0.6 the folders for translations were moved inside the Audacity bundle (Audacity.app is actually a folder on Mac OS X). That allowed some items in the Audacity menu bar to be translated into the system language, irrespective of what language Audacity was set to.
If my guess is correct, the question is why the translations are not made correctly.
I'll see if I can find anything out.
Problem is not due to translation, but probably due to bad(?) handling with utf-8/non-utf-8 strings (or something like that).
I found these device names in "Audio MIDI Setup"(a bit confusing name of app) so they're really exists directly in system, not in Audacity and its translation files:
- Quality Assurance
Yes that is what I meant. Moving the language files into the app bundle is presumably causing the system translations of device names to be used, but those translations are not displaying correctly in Audacity. Audacity does not supply translations of device names. Leland (a Mac developer) will have a quick look at the problem.kmarty wrote:Problem is not due to translation, but probably due to bad(?) handling with utf-8/non-utf-8 strings (or something like that).
If this is a big problem for you and you don't mind Audacity running in English, then right-click over Audacity.app > Show Package Contents, then open the "Contents" folder then the "Resources" folder. Rename cs.lproj to xx.lproj or something that is unused and restart Audacity. Then everything in Audacity will be in English including the device names.
Ah, ok. Sorry, misunderstood on my side.
I'm able to reproduce this (which is the biggest part of the battle), so I hope to be able to track it down in short order. I'm pretty sure kmarty is correct about UTF mishandling, but time will tell.
Leland
Leland
I tracked down the problem to the way we were converting device names given to us by portaudio. Here's what I was getting before the fix (Audacity is in English, OSX is in French):
And here's what I get after:
Notice it's also fixed in the Device toolbar.
Leland
Leland
- Quality Assurance
Thanks, Leland for taking time to look at it.Leland wrote:I tracked down the problem to the way we were converting device names given to us by portaudio. Here's what I was getting before the fix (Audacity is in English, OSX is in French):
Leland
Assuming this bug is in Audacity, could you commit your fix or post a patch on bugzilla for review?
Bug created:Gale Andrews wrote: Thanks, Leland for taking time to look at it.![]()
http://bugzilla.audacityteam.org/show_bug.cgi?id=766
But, you'd better check it...would you believe this is probably the first bug I've created myself? I always just go off what you've put out there.
Leland
there are corruptions of UI Popup menu Text @ japanese aiso.
version: 2.0.6.0
OS: Mac OS X 10.9.5
Interface language: engilsh
version: 2.0.6.0
OS: Mac OS X 10.9.5
- Attachments
- スクリーンショット 2014-10-09 13.28.26.png (100.07 KiB) Viewed 1611 times
