Unable to import AAC files? [SOLVED]
Djard
Post by Djard » Wed Oct 01, 2014 11:58 pm
I "successfully" installed ffmpeg v2.2.2 and located the "avformat-55.dll" file in Audacity's library preferences. I believe I
followed the instructions carefully but still can't import an AAC file into Audacity. Maybe somebody can point out where
I messed up in the following steps that I used. Attached is a copy of the diagnistic log file that is over my head.
1. Edit -> Preferences -> Libraries.
2. Click on "FFmpeg library" download button.
3. Click on "Download" under "Windows" heading.
4. Click on "ffmpeg-win-2.2.2.exe" -> Save.
5. Close Audacity.
6. Browse to save location -> double-click on the downloaded file,
"ffmpeg-win-2.2.2.exe" -> Run -> OK -> Next -> Next. Choose
default location:
C:Program Files (x86)ffmpeg for Audacity
7. Next -> Install.
8. Finish -> re-launch Audacity.
9. Edit -> Preferences -> Libraries.
10. Click on "FFmpeg Library" Locate button.
11. Browse -> navigate to and double-click on "avformat-55.dll"
in the following location:
C:Program Files (x86)FFmpeg for Audacity
12. OK -> OK.
Djard
Re: Unable to import AAC files?
Post by Djard » Thu Oct 02, 2014 12:01 am
Oops! Here's the attached log file.
Audacity Log File.txt
(39.37 KiB) Downloaded 197 times
Post by steve » Thu Oct 02, 2014 1:47 am
FFmpeg v2.2.2 is for Audacity 2.0.6.
You are still using Audacity 2.0.5 which uses an older version of FFmpeg.
Audacity 2.0.6 is available here: http://audacityteam.org/download/
Djard
Re: Unable to import AAC files? [SOLVED]
Post by Djard » Fri Oct 03, 2014 3:41 am
Ooh, new version...yay! Thanks.
