I want to blank out a part of sound file
Towley
Post by Towley » Tue Sep 30, 2014 11:55 pm
I have a recording that is in MP3 format and my name is mentioned and I want to blank or beep this out for privacy reasons. Can I do this with Audacity? How do I do this ? Can you provide me a step by step guide (or point me in the direction of one) or a YT Video of this procedure.
thanks
Gunnar
Re: I want to blank out a part of sound file
Post by Gunnar » Wed Oct 01, 2014 12:17 am
Simply open your MP3 file in Audacity, select the part your want to "blank out", run Edit -> Remove Special -> Silence Audio and finally save the modified file.
However be aware that opening your MP3 file in Audacity and then saving it back to MP3 again will cause some quality loss! You may use a tool like mp3DirectCut to edit existing MP3 files in a 100% lossless way.
(In mp3DirectCut you can "blank out" a part by selecting the section to be removed and then run Edit -> Gain -> Silence -> OK)
Towley
Post by Towley » Wed Oct 01, 2014 3:34 am
cannot find menu item "remove special" under Edit
Post by steve » Wed Oct 01, 2014 5:56 am
Towley wrote:cannot find menu item "remove special" under Edit
The instructions given were for the current version of Audacity.
The current version of Audacity is 2.0.6 and is available here: http://audacityteam.org/download/
stearman65
Post by stearman65 » Wed Oct 01, 2014 8:50 am
Alternatively, open the recording in Audacity highlight the section, then either "generate silence" or " Edit Cut" or "Edit Delete", the latter two will shorten the track.
Stearman65
Post by Gale Andrews » Thu Oct 02, 2014 3:47 am
Or select the offending section and Generate a tone to beep it out.
