PortAudio error after upgrading to 2.0.6 [SOLVED]
Re: PortAudio error after upgrading to 2.0.6
I've attached the requested txt file and a screenshot of the popup error message.
- Attachments
- DxDiag.txt
- (30.01 KiB) Downloaded 29 times
- audio-error.jpg (263.83 KiB) Viewed 491 times
- Quality Assurance
Thanks. Presumably the same problem that fails the advanced checks in dxdiag causes problems for PortAudio.jwarsaw wrote:I've attached the requested txt file and a screenshot of the popup error message.
I suggest you open Windows Device Manager. Expand "Sound, video and game controllers". You may find yellow exclamation marks there. I suggest you uninstall all the audio devices, don't reboot, go to the HP web site then download the latest Windows 7 Home Premium 64-bit audio drivers for your HP Pavilion dm4 Notebook PC. Install the drivers then reboot.
Re: PortAudio error after upgrading to 2.0.6 [SOLVED]
Perfect! That solved my problem - thank you very much!!
