I think it would be kind of extraordinary if this problem shows up only in Audacity, while all other applications work absolutely flawlessly - many of which are much more demanding for the graphics card.steve wrote:What I guess is happening, is that your high performance dedicated graphics card is also doing its own caching. (Running two Hi Def monitors requires a huge amount of data). Unfortunately it seems that your graphics card is not quite "smart enough", and can be tricked (by rapid scrolling) to hold old cache data longer than it should, and so sometimes display low resolution (pixelated) waveform data rather than the most recent waveform data.
Until I spot a similar problem in another application, which I have not (so far), I have to suspect that it must be a problem on Audacity's side. Triggered only under certain conditions...
As mentioned above, I already use the latest WHQL drivers.steve wrote:A driver update for your graphics card (if available) may solve the problem
For LCD screens you don't have much alternative to running on the "native" resolution (anything else will be interpolated to the "native" resolution by the screen anyway). And you certainly wouldn't want thatsteve wrote:or making less demands on the card (for example, running only one monitor, or using lower definition, or a lower refresh rate).
Same about the refresh rate. Pretty much all LCD screens run at 60 Hz. Some of those fancy new "4K" screens can do only 30 Hz (because of a bandwidth limitation of the DVI connection) and the result is that the mouse cursor doesn't move smoothly anymore.
