Compile fails on SVN Audacity in OpenSUSE [SOLVED]
Building and customizing Audacity from the source code.
Etna
Operating System: OS X 10.6 Snow Leopard or earlier
Post by Etna » Sun Sep 28, 2014 2:28 pm
I'm currently attempting to build and install Audacity on OpenSUSE 12.2, x64.
And I have followed all the instructions listed in the following pages:
http://wiki.audacityteam.org/wiki/Devel ... ng_on_Unix
http://wiki.audacityteam.org/wiki/Compi ... ress_wxGTK
I have my own copy of WxGTK installed in /home/etna/Downloads/Applications/Audacity/dependencies. To make the compiler aware of the libraries, I have also done the following step:
Code: Select all
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/home/etna/Downloads/Applications/Audacity/dependencies/lib64
I have also configured Audacity with the following:
Code: Select all
WX_CONFIG=/home/etna/Downloads/Applications/Audacity/dependencies/bin/wx-config ./configure --with-libvorbis --with-libflac --with-ffmpeg --with-lame --with-libid3tag --with-libmad --prefix=/home/etna/Downloads/Applications/Audacity
However, when running make, the build fails at the linker stage with a ton of messages pointing to undefined reference to 'wxString...' as shown in the pastebin link: http://pastebin.com/wKf9gF6T
Any assistance will be greatly appreciated.
Re: Compile fails on SVN version of Audacity in OpenSUSE
Post by steve » Sun Sep 28, 2014 3:30 pm
Etna wrote: And I have followed all the instructions listed in the following pages:
In http://wiki.audacityteam.org/wiki/Compi ... ress_wxGTK did you do the step labelled "Instant gratification (optional)" and make the "minimal" sample program? Did that run correctly?
Post by Gale Andrews » Tue Sep 30, 2014 9:43 am
Did you build shared libraries of wxGTK?
Did you you build unicode release version of wxGTK and is that the default version? Check at:
Code: Select all
wx-config --list
Etna
Re: Compile fails on SVN Audacity in OpenSUSE [SOLVED]
Post by Etna » Mon Nov 03, 2014 6:43 am
It was compiled with Unicode support.
For some reason, deleting all the sources and rebuilding them once again results in a successful build. Odd.
But hey, at least it's working now.
