hello
please see the snap shot in attachement
i cannot access the x - + sign nor do resize the window
thanks for your help
Audacity title bar missing [SOLVED]
atomottokar
- Attachments
- Screen Shot 2014-09-25 at 9.42.07 PM.png (59.38 KiB) Viewed 522 times
Reason: changed title to be more descriptive
atomottokar
Re: Audacity title bar missing [SOLVED]
working if i click on " window > zoom "
thanks anyway .
marche bien si l'ont click sur " window > zoom "
merci
thanks anyway .
merci
- Quality Assurance
Thank you for telling us how you solved the problem.atomottokar wrote:working if i click on " window > zoom "
thanks anyway .
merci
