compatible record needle for my turntable a Deson DS106
Did you buy a new mixer? Do you need advice? Post here.
Kriz441
Post by Kriz441 » Tue Sep 23, 2014 9:49 pm
Hi, I'm looking for a compatible record needle for my turntable a Deson DS106, There are a lot of stylus avaialble but seems to be a compatibility issue between makes models etc, Any ideas would be greatly appreciated. :)
Moderator note: please do not piggyback unrelated posts onto an existing thread as it confuses the thread for readers. I split this post off for you.
waxcylinder
Re: compatible record needle for my turntable a Deson DS106
Post by waxcylinder » Wed Sep 24, 2014 8:11 am
We can't help you with that - you need to speak to the Manufacturer about that - or the shop you bought it from
Deson website: http://www.deson-hk.com/about/show.php?lang=en&id=48
or try this turntable forum: http://www.vinylengine.com/turntable_forum/index.php
Kriz441
Post by Kriz441 » Wed Sep 24, 2014 9:39 pm
Hi waxcylinder Thanks, I contacted the manufacterer and will let you know how i get along.
