Any way to organize my effects list? Part 2
This read-only archive contains discussions from the Adding Feature forum.
New feature request may be posted to the Adding Feature forum.
Technical support is available via the Help forum.
Re: Any way to organize my effects list? Part 2
Post by Gale Andrews » Fri Sep 19, 2014 11:16 pm
Robert J. H. wrote:For some effects, the manual definition wouldn't be bad. Vst plug-ins in particular tend to be ill-named and have either Vst in Front or the manufacturers name.
I'm personally not interested in the fact that it is a Vst-plug-in but rather if it is a limiter or a phaser.
See plugins.cfg in the Audacity folder for application data:
  • Windows 2000/XP: Documents and Settings<user name>Application DataAudacity
  • Windows Vista/Windows 7/Windows 8: Users<user name>AppDataRoamingAudacity
  • OS X: ~/Library/Application Support/audacity/
Effect Menu displays the VST effect by displaying the "Vendor" text in plugins.cfg, adding a colon, then displaying the "Name" text. So you can make the effect display in the menu as you choose by editing plugins.cfg, for example you could have it display as "Normalizer: Level Booster" by making Vendor=Normalizer and Name=Level Booster.
Just bear in mind that VST rescan will wipe out your custom text in plugins.cfg. :evil:
If the effect starts with "VST:" in the Effect Menu this is because the plug-in manufacturer supplied no vendor name. So if you wanted to start the text in Effect Menu with "VST:", just leave the Vendor text empty.
Robert J. H.
Post by Robert J. H. » Sat Sep 20, 2014 1:11 am
I've long ago abandoned modifying the config file because of your mentioned points.
It will make sense again as soon as effects can be added one at a time and without restarting Audacity, i.e. on the fly.
