Where'd the rest of the export dialogue box go?
Please state:
tomreid
Post by tomreid » Tue Sep 09, 2014 11:59 am
Hi
I'm using audacity 2.0.0. on a Dell Mini 10v running LXLE (forked from Lubuntu) the version of Audacity on the system was included with the operating system download.
Pretty simple question. When I export an audio file (I click File, then Export) on my desktop I have choice of different file formats to export to showing at the bottom of the export dialogue box.
When I click File, then Export on the netbook, it's like the bottom half of the dialogue box is missing and I can't change the export file format.
Any ideas anyone?
cheers
Re: Where'd the rest of the export dialogue box go?
Post by Gale Andrews » Tue Sep 09, 2014 5:38 pm
tomreid wrote:I'm using audacity 2.0.0. on a Dell Mini 10v running LXLE (forked from Lubuntu) the version of Audacity on the system was included with the operating system download.
Please be aware 2.0.0 is now five versions (soon six versions) old.
tomreid wrote:When I export an audio file (I click File, then Export) on my desktop I have choice of different file formats to export to showing at the bottom of the export dialogue box.
So is the netbook on "LXLE" and what OS is the desktop running?
What screen resolution is the netbook set to?
Also please attach an image of what you see. Please see here for how to attach files: http://forum.audacityteam.org/viewtopic ... 49&t=64936 .
