Consistent interface for filter effects
This read-only archive contains discussions from the Adding Feature forum.
New feature request may be posted to the Adding Feature forum.
Technical support is available via the Help forum.
Paul L
Post by Paul L » Fri Aug 29, 2014 3:14 pm
For High and Lowpass filter dialogs, the frequency input field is not first in tab order.
For notch filter, it is (which I find more convenient personally).
Would it be nicer to make them consistent?
It's a simple matter of Nyquist programming of course, so I can easily do it for myself if I prefer that.
Robert J. H.
Re: Consistent interface for filter effects
Post by Robert J. H. » Fri Aug 29, 2014 6:02 pm
Paul L wrote:For High and Lowpass filter dialogs, the frequency input field is not first in tab order.
Those are not the same filters.
The Notch filter is of second order only. Hp and Lp go up to order 8 and the first field expresses that.
Paul L
Post by Paul L » Fri Aug 29, 2014 9:16 pm
Robert J. H. wrote: Those are not the same filters.
Sure, but each has a frequency slider and there is inconsistency in the user interface. Most users don't care about the math, and usually I don't either. :-)
Robert J. H.
Post by Robert J. H. » Fri Aug 29, 2014 10:59 pm
It's not about maths. It's about foing down in the decision tree:
- What type?
(only Butterworth available)
- what sub-type?
(via effect menu, Low-Pass, High-Pass, Band-Pass, Notch...
The shelf filter has HS and LS as first choice in the GUI)
- What order
(Only available for Hp and Lp)
- What cut-off frequency?
(The sample rate is given)
- How much ripple?
(Chebichev only)
- What Gain?
(only for shelf/peaking EQ filters)
- What Q-factor?
(or bandwidth or slope, falls away for cascaded filters higher than order 2)
The inconsistency gets worse if you enable the classic filters in Audacity, the cut-off frequency is the very last input control.
Apart from anything else, the users are now perhaps to familiar with the HP and LP layout and wouldn't appreciate a change.
