WAV files not compatible to burn audio CD's
Peter de Jong
Hello, I use Audacity 1.2.6 to digitalise my LP's with a Lenco TT (L-3866USB) and found out that the exported *.wav files cannot be used to make audio CD's with Nero 6
Nero gives: 'not supported file format'.. Experts tell me that the files made with Audacity 1.2.6 are not 'compatible' to use in international standard CD's. I therefore make my audio CD's by using exported *.MP3 files instead. This procedure goes well in Nero but seems to give less quality CD's (because the original files are compressed I think). Does somebody know how to burn the exported *.WAV files of a LP on a audio CD? Should I f.e. use the Audacity beta (unstable) programme
Re: WAV files not compatible to burn audio CD's
Make sure you are exporting your WAV files as 16 bit, not 32 bit. Nero only recognizes 16 bit WAV filesPeter de Jong wrote:Hello, I use Audacity 1.2.6 to digitalise my LP's with a Lenco TT (L-3866USB) and found out that the exported *.wav files cannot be used to make audio CD's with Nero 6Nero gives: 'not supported file format'.. Experts tell me that the files made with Audacity 1.2.6 are not 'compatible' to use in international standard CD's. I therefore make my audio CD's by using exported *.MP3 files instead. This procedure goes well in Nero but seems to give less quality CD's (because the original files are compressed I think). Does somebody know how to burn the exported *.WAV files of a LP on a audio CD? Should I f.e. use the Audacity beta (unstable) programme
Tony
Art & Lutherie Cedar Folk CW 6 String Acoustic
Pre-Martin Goya 12 String
Vestor Bass
And a bunch of other ends and odds!
http://www.tonyseomusic.com/
http://www.myspace.com/tonyseomusic
http://www.soundclick.com/tonyseo
Vestor Bass
Peter de Jong
Thats it!
THANKS, I used 32 bit in stead of 16 bit
