Help!!! Can't install Gsnap
Zach456
Post by Zach456 » Fri Aug 29, 2014 4:11 am
Does any one know how to install gsnap. I followed the instruction in the Youtube video https://www.youtube.com/watch?v=CvIwA89mfIE but gsnap does not show up in my effects
Re: Help!!! Can't install Gsnap
Post by Gale Andrews » Fri Aug 29, 2014 7:58 am
Audacity does not author or validate YouTube videos which may be plain wrong (or as in this case, wrong because they missed out installation steps).
Audacity does author a Manual, which I suggest you look at: FAQ: How do I install VST plug-ins? .
So as you have now learned, the step missing from the video is that you have to open the Effects Preferences, enable rescan of VST effects then restart Audacity.
kattkins
Post by kattkins » Thu Oct 16, 2014 10:16 pm
I have had the same problems: Gsnap is not showing up under the effects tab. However, I followed the whole "rescan for VST plugins" in the preferences section. The box showing the new .dll files to install turn up, and I can click ok, but the effects never show up when I re-open Audacity. I have the plugins saved in several different folders that should be able to be accessed by Audacity but it still doesn't change anything.
Post by steve » Fri Oct 17, 2014 12:43 am
PLEASE read the important message highlighted in red/pink at the top of this page.
We are unable to help you without basic information about your set-up.
Topic locked.
If you still need help, please post in the appropriate forum for your operating system and include information about your set-up (including: which version of Audacity and which version of which operating system).
Post by Gale Andrews » Fri Oct 17, 2014 12:21 pm
steve wrote:PLEASE read the important message highlighted in red/pink at the top of this page.
It sure helps if you do what Steve asked. But in this case it's obviously Windows (see "DLL") and obviously it's 2.0.4 or later (otherwise there would not be the "Install VST Effects" dialogue).
If you see GSnap in the "Install VST Effects" dialogue and make sure that it is ticked, and if you downloaded the 32-bit version of GSnap, then it will appear in the Audacity Effect Menu, underneath the divider, called "GVST:GSnap".
I'll unlock this for a few days to allow you to reply. Then it will be locked again.
