The Equalizer needs a gain control (v.2.0.5)
Black Dog Bluez
- Operating System: Windows 7
The EQ is cool and simple but hard to preview when I EQ a lot out because the volume drops, as it should. Which I of course fix after, but as I said, it makes it hard to Preview. One trick I accidentally learned, is doubling the track and and then highlighting both, then go to EQ and set then Preview. Save, then go back and highlight just the one track and apply the saved EQ curve. --Hopefully a gain (like the 'Bass and Treble' effect already has) and Real-Time!! would be nice for the next version of Audacity. --The best free music editor!!
Re: The Equalizer needs a gain control (v.2.0.5)
+1 for a gain control on the Equalization effect.
The way that I envisage this working is as a vertical slider that raises/lowers the Eq curve ("Draw Curves" mode), or all of the sliders in tandem ("Graphic EQ" mode) while retaining the current "shape".
Tim Lookingbill
- Operating System: OS X 10.6 Snow Leopard or earlier
Linear or Log volume increase behavior options? It would be nice to be able to listen for EQ curve edit induced tonal imbalance hot spots that would mimic the same effect as increasing the system wide volume knob which is what I currently have to do while the EQ curve tool is open. Sibilance tends to sound comfortable at normal volumes but make my ears bleed at higher.steve wrote:+1 for a gain control on the Equalization effect.
Robert J. H.
There should actually be two sliders:steve wrote:+1 for a gain control on the Equalization effect.
1. scales the shape
2. shifts the shape up and down
The first one would determine the flatness of the curve and is the most important one imo.
e.g. "0 0 4 -3 -2 dB" gives "0 0 2 -1.5 -1 dB"
This would naturally replace the "Flatten" and "Invert" buttons.
The second slider is responsible for the overall gain.
e.g. "0 0 4 -3 -2 dB" gives "1 1 5 -2 -1 dB"
Can be realized with two buttons +/-1 dB (which goes immediately into the sliders/curve)
or as a virtual offset slider (the indiv. slider positions stay the same).
I miss the scaling slider the most.
However, I think you're rather for the second one, aren't you.
Topic moved to "Adding Features" board.
If it could be implemented as an "advanced interface option", then I'd probably be in favour as I can see its usefulness, particularly for users that don't use pointing devices.
Unless that could be an "advanced interface option" (disabled by default), I'd be slightly against that. I can imagine inexperienced users being very confused if they inadvertently set the "scale curve" to "flat" because the other sliders would appear to not work. Also, I don't think that it could be implemented sensibly in the "Draw Curves" view, so there would be a disconnect between "Draw Curves" and "Graphic Eq" views. (There already is a bit of a disconnect between the two, but that's a bug that should be fixed).Robert J. H. wrote:The first one would determine the flatness of the curve and is the most important one imo.
- Quality Assurance
I agree with Steve this would need to be hidden (or use a text envelope tool instead).steve wrote:Topic moved to "Adding Features" board.
Could there not be some simpler single control for this like a slider?
Robert J. H.
I see it rather as an jumping slider. It would always return to "100%" scale, as soon as the slider looses focus.steve wrote:Topic moved to "Adding Features" board.
So, if we have
Code: Select all
-100_0_100_200 %The same principle if we keepp the two special buttons:
Code: Select all
Scale by 0.2 0.25 0.33 0.5 <1> 2 3 4 5Code: Select all
<Stretch Curve> <Squeeze Curve>By the way, it is annoying that the sliders' range is fixed to +/- 20 dB.
