Help......see screenshot
rj7500
Post by rj7500 » Fri Aug 22, 2014 2:07 pm
This problem began yesterday after I had to do some major furniture rearranging and reconfiguring my hardware.
Running Audacity 2.0.3 on an HP Pavilion
Windows 8.1
The input is a Presonus Audiobox.
The screenshot represents 3 input scenarios
Top track is the Presonus input with no microphone attached
The other 2 tracks are the default Windows inputs
I really need some fast help as I have a project due today
Thanks in advance
Bob H
Screenshot (9).png (144.1 KiB) Viewed 367 times
rj7500
Re: Help......see screenshot
Post by rj7500 » Fri Aug 22, 2014 2:35 pm
Gentlemen...........stop
I found the problem and it was a bad USB Hub........plugging the Presonus directly into a USB port on the computer solved the problem.
Thanks for your efforts and sorry to have bothered you
Bob H
Post by kozikowski » Fri Aug 22, 2014 3:59 pm
It was not a bad USB hub. It was any USB hub.
rj7500
Post by rj7500 » Fri Aug 22, 2014 4:09 pm
True, but the computer designers seem to be cheating on the number of USB ports lately. If one is using many peripherals the port is unfortunately a must have.
Anyway, Thanks Koz for your help.
Bob H
Post by steve » Fri Aug 22, 2014 4:40 pm
rj7500 wrote: If one is using many peripherals the port is unfortunately a must have.
No problem, use the hub with your mouse, keyboard, printer, scanner, lava-lamp, chess game, photoframe, ... just not with your audio interface which requires reliable real-time data streaming. :)
