mp3 music file volume modification [SOLVED]
semperfi57
Post by semperfi57 » Wed Aug 20, 2014 9:22 pm
The mp3 music folders in our music library have been recorded at various amplitudes (volumes).
Can this software function as a volume control/equalization to elimenate the variances
in the recorded volumes.
Something like a limiter on the tape recorders.
Thanks,
here is a typical mp3 file on our system.
Re: mp3 music file volume modification
Post by kozikowski » Thu Aug 21, 2014 2:46 am
Since this is a Mac, you can use SoundCheck® to push all your music toward the same volume. Attached.
Screen Shot 2014-08-20 at 7.44.16 PM.png (67.86 KiB) Viewed 704 times
semperfi57
Post by semperfi57 » Thu Aug 21, 2014 2:57 pm
This is a DELL computer.
Is there a way to have the sound check do all of the songs in a folder at once?
Thanks,
Gerry
Post by Gale Andrews » Thu Aug 21, 2014 3:08 pm
semperfi57 wrote:This is a DELL computer.
But you still showed a picture of iTunes. Use Sound Check. See http://support.apple.com/kb/HT2425 .
Gakle
semperfi57
Post by semperfi57 » Thu Aug 21, 2014 4:08 pm
Thanks for your reply.
I did use sound check, but, the volume differential from song to song does not change from the original recordings in our music file.
Perhaps, I'm not doing something right?
Thanks in advance,
Gerry
Sound Check.jpg (128.84 KiB) Viewed 661 times
Post by Gale Andrews » Thu Aug 21, 2014 4:22 pm
semperfi57 wrote:Perhaps, I'm not doing something right?
Did you consider using Sound Check in Playback Preferences as per Koz's image, or reading the link I posted http://support.apple.com/kb/HT2425?
semperfi57
Post by semperfi57 » Thu Aug 21, 2014 5:25 pm
Please let me work this over the weekend.
Thanks again,
Gerry
Robert J. H.
Post by Robert J. H. » Thu Aug 21, 2014 7:28 pm
I often use Foobar2000 to update the replay-gain (similar to sound check) level.
The nice thing is that it can alter the tracks permanently and not only by a virtual ID3-tag which will be ignored in some players.
satguru59
Post by satguru59 » Sat Aug 23, 2014 7:44 am
You can Do this with Audacity, I Think this forum is of Audacity So we should Explain tutorial for that... 8-)
Import your Mp3 files ( Which you want to decrease or increase the amplitudes )
Step1:)
Use Zoom tool to Zoom the segment where variances are there
Step2:)
Use The Selection Tool to select the segment of variances
Step 3:)
Click on Effect then select Amplifiy to Decrease or increase the Amplitude of Selected Segment.
Last Step4:)
Export the Mp3 files ( You will need Lame mp3 decoder If you dont have one)
Note: You can Create "Chain "If You don't want to repeat the tasks again and again manually it will repeat to apply the effect in all mp3 files.
semperfi57
Post by semperfi57 » Sat Aug 23, 2014 2:05 pm
satguru59 wrote:You can Do this with Audacity, I Think this forum is of Audacity So we should Explain tutorial for that... 8-)
Step1:)
Step2:)
Step 3:)
Last Step4:)
Thanks satguru59.
Perhaps this tutorial might best be resolved using specific instructions by email:
[e-mail address removed]
I did drag & drop a song onto the audacity icon but need the next few steps.
I don't have the Lame mp3 decoder.
Thanks in advance,
Gerry
