'70's/'80's CD music remix examples using Audacity
Trebor
Re: '70's/'80's CD music remix examples using Audacity
Post by Trebor » Thu Aug 21, 2014 1:58 am
Tim Lookingbill wrote:I gather from that and the "Modern Spacer" YouTube video these plugins appear to be more designed for subtle enhancements ...
The spacer VST is essentially a reverb effect : it simulates acoustics of a room you would wish the performers or loudspeakers were in , it can create a wider stereo image , there is a plug-in specific to Audacity called stereo widener which does something similar. Plugins are not limited to "subtle enhancements" some can make the music unrecognisable.
Tim Lookingbill wrote:What I've found to be the biggest problem in particular with this piece and others with similar dynamics is the difficulty surgically EQ'ing to bring out the punchy portion of the kick drum without making the bass guitar too boomy ...
A multiband compressor ( like the free Gmulti) may be the solution : it can compress specific frequency bands, e.g. bass frequencies only.
Compressors are dynamic and only attenuate when the signal, (in that frequency-range), goes above a threshold you have specified , when below threshold it does nothing.
Tim Lookingbill wrote:... can those VST plugins you linked to edit the waveform or are they only designed to be used in host apps that allow real time play through sound shaping?
I used those VST plugins installed in Audacity. When using VST plugins in Audacity you have to press the "Preview" button on the bottom left of the effect's controls to hear how it sounds, in Audacity you can't adjust the controls while the preview is playing :¬( and any animation in the plug-in controls won't work. The duration of preview can be altered in Audacity's preferences , personally I find 3 seconds is plenty time to assess how an effect sounds.
Robert J. H.
Post by Robert J. H. » Thu Aug 21, 2014 12:44 pm
Trebor wrote:... personally I find 3 seconds is plenty time to assess how an effect sounds.
Not in my opinion. I've set it to 30 seconds. Firstly, I can always cancel the preview with space bar. You can often not tell how an effect interacts with other portions of the sound later on. A de-esser may sound fine on the first 3 seconds but horribly on a following "sh" or "dj" sound.
Also, you might want to use the effect on a whole track (for consistency sake) but how do you want to judge a stereo widener from a drum and bass intro?
Tim Lookingbill
Operating System: OS X 10.6 Snow Leopard or earlier
Post by Tim Lookingbill » Fri Aug 22, 2014 2:13 am
Upon investigating Trebor's links to VST plugins and later sadly finding out they're for Windows only (I'm on a Mac) at least it got me motivated to further investigate what level of sound shaping to expect out of a multiband compressor which lead me to this wonderful demonstration...
https://www.youtube.com/watch?v=U2qkIeSFzy8
Can't afford that plugin but it got me to twiddle and experiment changing the 3 frequency band crossover Hz numbers within Audacity's AU Multiband Compressor (Fast & Smooth preset) and finally got acceptable results if only I could figure out a way to control what gets loud and soft over my other previous "EQ/Amplify" methods. I guess I could apply the effect in sections of the music.
Most of that plugin's settings are pretty hard to figure out what affects what part of the sound. How do you determine threshold within the entire spectrum of a waveform and relate it to the plugin settings and sound level?
I also finally figured out how to control bass frequencies within Audacity's AU MatrixReverb plugin by changing the default '3' in the Octave setting to '1' starting at 800Hz editing the "Plate" menu preset, my favorite reverb so far.
Tim Lookingbill
Post by Tim Lookingbill » Sat Aug 23, 2014 12:00 am
Guess I'll cap this thread off posting my own "Before/After" Audacity edit mp3 of the same sampled section of the YouTube Maynard Ferguson "Awright, Awright" only I've sampled off my purchased copy of the CD's aiff on which I applied the edits, saving in 32bit floating point .WAV format.
WARNING!
Before you listen to the mp3 sample set your volume at half mark especially with headphones. I applied a round shaped fade-in using Audacity's "Adjustable Fade..." to the louder edited version so it will be a very slow progression to max volume. It ends at the loudest with a trombone solo, not the screaming trumpets.
I was surprised to find how big and loud I could get it and still retain detail just using Audacity tools. My first attempts back in March are pretty pathetic by comparison mainly due to my lack of familiarity with AU plugins (MultiBand Compressor/MatrixReverb) as well as my lack of patience on account of looking for an easy quick fix.
Here's the list of edits...
1. -7 setting in "Change Speed..." plugin. Gorgeous results, no artifacts.
2. +12db EQ notch curve with start end points at 60-70hz to isolate the punch of the kick drum (Hardly made a dent but it gave me something to work with later)
3. 30% wet/dry, 5% small/large, 800hz filter frequency, 1 octave filter bandwidth in AU MatrixReverb plugin (Plate preset) which opened up the stereo imaging and preserved bass.
4. Additional EQ to put back the brightness, loudness and clarity reduced by the reverb
5. Duped the waveform, reduced to single channel mono & applied 3 times 70Hz LowPass @48db roll off, reset max peaks to .1 in Amplify, applied same settings to HighPass for 2 channel, no amplify, mixed & rendered back down to 2 channel stereo.
6. Now to make it louder...applied George Yohng's W1 Limiter (best free one I've found so far...My apologies to Steve) Here are the settings...
Threshold: -6db, Release: 250ms with Adaptive Release selected, Ceiling: -0.2db (And yes the waveform is a brick wall but detail is still preserved) Kick drum punch in "Plot Spectrum" shows a 65Hz peak at -4db in some parts of the 7 minute song. YIKES! Compare that to the kick drum peak in the original aiff which is around 80Hz @ -20 to -30db.
Questions, criticisms and comments welcome.
Awright, Awright-A_B Loud-Big.mp3
(877.19 KiB) Downloaded 286 times
Trebor
Post by Trebor » Sat Aug 23, 2014 4:17 am
Tim Lookingbill wrote:... Here's the list of edits ...
Attachment : Awright, Awright-A_B Loud-Big.mp3
I'm surprised you changed the speed, doing so has also changed the pitch.
Usually that's only applied when the record/tape was running at the incorrect speed , [so not applicable to CDs].
But there are no rules when it comes to taste : you can modify audio anyway you like.
Audacity does have two options to change speed without changing pitch :
"Change Tempo" and "Sliding Time Scale / Pitch Shift ", both create digital artifacts though.
Awright, Allwrong - progressive slowing whilst maintaing pitch.mp3
Using Audacity's "Sliding Time Scale / Pitch Shift " effect , (no pitch shift).
(955.71 KiB) Downloaded 118 times
[ "Changing Pitch" without changing tempo is also available ].
Tim Lookingbill
Post by Tim Lookingbill » Sat Aug 23, 2014 8:23 am
Trebor, this particular song off the "MF Horn 3" album is the only one I applied the speed/pitch change to for a number of reasons that not only include the artifact issue with the other plugins, but as a former trombone player in similarly styled bands I've become quite familiar with the way brass instruments should sound. Also I was told in my youth by music instructors that I have a good ear.
The vinyl LP sounded the same back in '78 as it does on the CD, but it took the YouTube video I linked here to confirm my suspicion that speed and not only pitch were the main cause for the tinny inaccurate sound. I mean really, 80Hz kick drum/bass punch is ridiculous for bass frequencies of funk styled music.
Also most sub/satellite audio systems have their bass crossover networks at 80Hz. Playing the CD in my car equipped with such a system the punch of the bass is being played only through my back dash 6x8 Polks (with 80Hz bass blockers) where the two 10" subs in the trunk remain quiet. No car CD player 3 band EQ can fix it. I tried it. I don't have this issue with other funk styled music no matter by who or when or what media format mixed/mastered to except for Sly and the Family Stone Greatest Hits CD. Sounds like AM radio.
What's funny is I was told by home audio experts and salesmen back in the late '70's when I first played the MF Horn 3 vinyl LP that I needed an expensive high wattage system to get the sound I wanted. Fortunately I didn't (couldn't) buy into that. But in '87 I had the opportunity to play similar sounding '70's vinyl LP's (Weather Report's "Mr. Gone" album) on a $10,000 Bang Olufsen home audio system with no improvement to the sound.
Tim Lookingbill
Post by Tim Lookingbill » Sat Aug 23, 2014 10:25 am
Here's a no pitch/speed dynamics/loudness edit to "River People" off the 1978 Weather Report "Mr Gone" album as it sounded on the 1978 vinyl LP as well as the 1991 CD [Digitally Remastered Directly From The Original Analog Tapes] Whoopty-DO!
Even the $10,000 Bang Olufsen system couldn't make it sound this way even with its huge EQ board. Or maybe I just didn't want to have to fool with it since it was my roommate's system at the time and he didn't want anyone messing with his setup.
Note the tap sound that is suppose to be the kick drum, I'm guessing. This time I found a good use for the AU MultiBand Compressor and it worked beautifully on this particular piece. Just applied it after listening with a fresh ear and not realizing the level of murkyness in my final edit. Glad I wrote down the AU MBC custom settings. Didn't have to go to the trouble of coming up with an EQ curve. Here's the edits...
1. 30% wet/dry on AU MatrixReverb "Plate" menu preset.
2. Clarity EQ with 18db bass ramp peak at 70Hz.
3. AU MultiBand Compressor settings..."Fast and Smooth" defaults: -5db post-gain, Crossover 1,2,3=100, 3000, 15000, EQ1:9db, EQ2:9db, EQ3:13db, EQ4:0db
4. W1 Limiter: all settings the same except threshold at -3db
WeatherReport-River People_AB.mp3
(379.23 KiB) Downloaded 245 times
Trebor
Post by Trebor » Sat Aug 23, 2014 2:25 pm
Tim Lookingbill wrote:WeatherReport-River People_AB.mp3
IMO there's some bass* you've missed out on between 200Hz and 100Hz ...
click on this image to see it in its entirety
before-after equalization + limiter only.mp3
(725.71 KiB) Downloaded 189 times
The equalization depends on the type of speakers/headphones, your hearing, and how loud it is.
* http://manual.audacityteam.org/o/man/plot_spectrum.html [change "linear frequency" scale to "log frequency" to see the bass clearer]
Tim Lookingbill
Post by Tim Lookingbill » Sat Aug 23, 2014 4:01 pm
Trebor, I always go by Log scaling in the Plot Spectrum. That's how I located the punch of the kick bass which is mostly what I'm interested in.
And IMO your increasing lower midrange bass frequencies (100-200Hz) on a non-reverb version (no opened up stereo imaging) isn't really comparing apples to apples so I'm not hearing an improvement in bass response over what I did. The hum of this bass region tends to reduce overall clarity and often perceptually gains when amplified on speakers listened to in an enclosed environment (living room/car) which is what I'm hearing from your treatment even on my Sony MDR V6 headphones.
Are you saying what you're hearing from my edit is thin sounding? Not loud and full? What are you listening on? Or are you basing your judgements strictly on plot spectrum measurements?
Tim Lookingbill
Post by Tim Lookingbill » Sat Aug 23, 2014 6:22 pm
Trebor, OK, you got me going on that 100-200Hz thingy to the point it motivated me to apply the same 80Hz/48db LowPass/HighPass mono channel bass boost to the finished RiverPeople version before multiband compression. Then I applied MBC but this time I amped the bass EQ1 from 9db to 15, EQ2 from 9db to 12 and EQ3 from 12db to 15. Applied -6db threshold to W1 Limiter.
Boy was I wrong about getting all the bass in this file! OMG! Not only did I get the punch but I got the beef to go with it and still preserve the Plate reverb effect. WOW! This turned out better than I thought. Thanks for the motivation, Trebor.
River PeopleBigLoudBeefy.mp3
(401.27 KiB) Downloaded 318 times
