Hey! That's not bad.
I'm also messing around now at balancing gain levels between original 'reverby' take and 'de-noised' duplicate and playing them back together
Original has a 10 second intro of assorted percussion and a couple of other interludes which don't fare quite so well at the de-noised optimum for the rest of the track when the rhythm and/or vocals are on the go.
Mitigate overdose of reverb
Re: Mitigate overdose of reverb
No, but if you reduce the amplitude of the original work 10dB, take the profile, and then boost it back up, haven't you done the same thing?However, the tool isn't not intended for this purpose after all.
Robert J. H.
I should guess so.kozikowski wrote:No, but if you reduce the amplitude of the original work 10dB, take the profile, and then boost it back up, haven't you done the same thing?However, the tool isn't not intended for this purpose after all.
However, the version for 2.1.0 is different and sensivity won't be related in that fashion anymore.
In other words, pre- and post-amplification is the only way in future.
