Enhancing/mastering 1970's cassette recordings
Trebor
Re: Enhancing/mastering 1970's cassette recordings
Post by Trebor » Mon Aug 11, 2014 2:18 am
elance wrote:... Can you explain just a little how you did the envelope? I am looking at the manual on it but not sure exactly what i'm looking for to change.
You have to click on the tool icon with the blue line Image to go into envelope mode ...
To leave envelope mode, click on the icon that looks like a capital "i".
elance
Post by elance » Mon Aug 11, 2014 2:27 am
thank you for the video, really helps. So I'm looking for peak areas and I level them out right?
Trebor
Post by Trebor » Mon Aug 11, 2014 2:58 am
elance wrote: So I'm looking for peak areas and I level them out right?
It's how they sound rather than how they look , the too-loud (or too quiet) bits may not actually be conspicuous on the shape of the envelope.
A compressor (or limiter) will try to make the waveform a constant amplitude, but to the ear this may make some things too loud, e.g. when there is a solo.
PS
after looking at the spectrogram view on Audacity , I've had another go at the EQ ...
#CASH, EQed#2, pseudostereo, envelope[drum].mp3
EQ#2 I've reduced reduce 1KHz-2KHz , and boosted +5KHz
(553.57 KiB) Downloaded 184 times
Tim Lookingbill
Operating System: OS X 10.6 Snow Leopard or earlier
Post by Tim Lookingbill » Wed Aug 13, 2014 2:41 pm
New to these forums but not with using Audacity. Took a crack at the OP's sample mp3 by first applying an EQ shown in the screengrab png, duplicated the single channel and turned it into stereo and applied AUMatrixReverb plugin selecting Plate with a 30% dry/wet mix.
cashsampleEdit2.mp3
(522.48 KiB) Downloaded 261 times
