I think it would be better to revert for now.waxcylinder wrote:Yes... I just discovered that - see: http://manual.audacityteam.org/man/Tuto ... cted_audioGale Andrews wrote:There is another downside. The syntax is:but that syntax kills the hover text. I've not found a working solution for that.Code: Select all
[[Image:Record.png|link=|Record button]]
Do you want me to revert those link- changes ?
Consistency says we should apply "link=" to small inline images (where hover text may not matter so much): http://manual.audacityteam.org/man/Cons ... ine_images .
Is that a reasonable distinction, so that (if we get the dump script changed) all but small inline images have hover text and open the image locally (but do not go to the development Manual)?
