1.3.6 Click Removal and Export Multiple?
This forum is now closed.
For help with current Audacity, please post to the 2.x. board for your operating system.
Please post feedback about the current 2.x version on the 2.x.feedback board.
Polleke
Re: 1.3.6 Click Removal and Export Multiple?
Post by Polleke » Wed Jan 07, 2009 7:11 pm
kozikowski wrote:People put one Label between two songs on a single timeline and are shocked when they only get one export. You need to put a Beginning Clip Marker at the [/u]Beginning[/u] of each clip you want exported. So the above example calls for a Label at 00:00 and then another one between the two songs. That will give you two exported songs.
For my job I'm kind of a mechanical engineer, and I'm always surprised (or shocked :shock: ) to see how end-users abuse and torture your design.
I guess the same applies to software.... what I usually do: I record a live-performance, and try to put as many info in the file "on the fly" as this saves me a lot of time afterwards in searching and marking songs. I'm all alone behind the soundboard, so I mix the band in all aspects: I have to keep eye contact with the musicians, mix volumes, play with effects and tone settings, watch the audience.... oh and by the way I also want to make a recording. So that has to go as easy as possible. I can't permit getting distracted by the computer.
This is why I changed some shortcuts. In this example: M is much easier than Ctrl-M.
Afterwards I edit the labels I set to their respective song names, save the original and export the whole bunch as separate MP3 files. To get the first song also I use the "export audio before first label" option, and give it the name of the first song (instead of the project name by default). By doing this I am not "shocked" (I quote) because I get the first track as well.
Are YOU shocked now? :D
Paul
Post by steve » Wed Jan 07, 2009 8:24 pm
I tried using customised short-cut keys for a while, but found that watching out for unpredictable things happening in Audacity was more distracting than having to find the default key combinations. Fortunately the Ctrl key is at the very corner of my keyboard so I can hit that without looking (but sometimes I miss the "M" :mrgreen: )
Polleke
Post by Polleke » Wed Jan 07, 2009 9:30 pm
Unpredictable? Uhm, right. That's just what I experienced now, to my surprise. Because in 1.3.4 just M worked fine. Apparently something else is fixed that caused this new bug.
