Sadly, the people writing the manual rarely receive detailed information from those contributing new code. This is an example of where the documenters seem to have drawn an incorrect conclusion about what the effect does. The manual suggests that the "Isolate" feature is the inverse of "Remove", but as you say, that is not the case.Paul L wrote:I read this in the 2.0.5 manual page for the effect:
With extreme high settings, what should happen is fairly clear.
If "Noise Reduction" is very high, then when removing noise, all of the noise should be removed leaving only the non-noise (ideally).
If "Noise Reduction" is very high, then when isolating noise, all of the non-noise should be removed leaving only the noise.
What is less clear is what should (ideally) happen for lower settings.
If "Noise Reduction" is zero and "Remove" is selected, we should remove no noise. Output = input.
If "Noise Reduction" is zero and "Isolate" is selected, then there are two possible ideal behaviours:
A) If we think of "Isolate" as the inverse of "Remove", then the result should be silence.
B) If we think of "Isolate" as "reducing non-noise", then the result should be no change. Output = input.
The 2.0.5 manual suggests case "A", but the effect behaviour is (almost) case "B".
As the effect in 2.0.6 will be the same as now, I've changed the 2.0.6 manual to say:
Isolate: Select this option to keep the noise and reduce other sounds in the selection.
