undo/redo history
Feedback and Reviews for Audacity 2.x
This board is ONLY for general feedback and discussion about Audacity 2.X.
If you require help, or think you have found a "bug", please post on the forum board relevant to your operating system.
Tapehead
undo/redo history
Post by Tapehead » Fri Jul 25, 2014 1:58 pm
How do you guys work around not being able to save this history when closing/saving a project that is in progress?
Re: undo/redo history
Post by Gale Andrews » Fri Jul 25, 2014 2:50 pm
Tell us how you would like to work around it then we can count your "vote".
Is it only the list of actions that you need from the last session? Or do you want to go back to a project state in the last session? That needs a lot of data to be stored on your computer.
Tapehead
Post by Tapehead » Fri Jul 25, 2014 6:22 pm
Thanks Gale.
Data storage isn't a big deal nowadays, an external terabyte Hard Drive doesn't cost that much.
I'd like to reload the last session exactly as it was before saving.
But being realistic in the meantime I'd guess only a few feature requests make it so I was also wondering what practice users adopted in the absence of this feature.
I find myself duplicating embellishment tracks a lot with various stages of effects applied or ctrl/shift/M mix overdubs to tracks whilst retaining the original individual tracks in case I question my nightime judgment the morning after
But then it all gets a bit messy with a huge amount of tracks to navigate.
Post by Gale Andrews » Sat Jul 26, 2014 11:25 am
You could perhaps save alternative mixes or effect attempts as a different project (File > Save Project As... ). Note this leaves you with the newly named project that you "saved as" open, its history including the states it had when it had its original name.
The project with the original name closes in the state it was last saved in, and of course loses its history.
You would have to try it out to see if it helped.
Tapehead
Post by Tapehead » Sat Jul 26, 2014 5:08 pm
I'll try that Gale.
I suppose I'm doing something similar in that I'm currently experimenting with opening a new project and copying selected tracks into it to play around with
I have a basic ryhthm'/outline track mix that is loaded into both to get approx levels
Another way I'm going to try is to export selected tracks as wavs for backups. I just found out that generating a small portion of silence from zero retains the white space before an instrument comes in.
Post by Gale Andrews » Sun Jul 27, 2014 12:03 pm
Tapehead wrote:I just found out that generating a small portion of silence from zero retains the white space before an instrument comes in.
Yes, that's another feature request (if you want to make it) that there should be a choice at export time to include leading white space as silence.
Tapehead
Post by Tapehead » Sun Jul 27, 2014 6:41 pm
Yes I'd vote for that.
Post by Gale Andrews » Mon Jul 28, 2014 1:25 pm
OK I will count your votes for those two features.
Tapehead
Post by Tapehead » Mon Jul 28, 2014 2:58 pm
Thanks Gale.
I'm still interested in how Audacity users work with absence of the undo/redo history after saving a project.
Post by steve » Tue Jul 29, 2014 5:28 am
Similar to you I think.
1) Regularly "Save Project As..." and give it a name in the form "name-of-project001", "name-of-project002", "name-of-project003", ...
Save alternative versions as "name-of-project-023", "name-of-project-023b", "name-of-project-023c", ...
2) Before modifying a track, make a duplicate of the track, Move the duplicate to the top of the project window and give it a meaningful name. Then mute and "collapse" the track.
3) Where possible, use "wet" and "dry" tracks for effects. For example, if applying reverb; duplicate the track and apply reverb "wet only" to the duplicate track. I can then adjust the wet/dry mix at any time (even while playing the tracks) by adjusting the track "Gain" sliders.
4) On larger project, work in sections. Have a separate folder for each section within an overall "name-of-project" folder, plus one extra folder for "Full-Mix".
The directory structure might look something like :
Code: Select all
My-show
   Source-files
      Person1
         person1-file.wav
         person1-another-file.wav
         person1-and-another.wav
      Person12
         person2-file.wav
         person2-another-file.wav
         person2-and-another.wav
      Piano
         Piano-first-bit01.wav
         Piano-second-bit01.wav
         Piano-another-bit.wav
      SFX
         gunshot.wav
         water.wav
         distant-bell-15b.wav
         distant-bell-46.wav
   My-show-part1
      part1-001.aup
      part1-001_data
      part1-002.aup
      part1-002_data
      part1-003.aup
      part1-003_data
   My-show-part2
      part2-001.aup
      part2-001_data
      part2-002.aup
      part2-002_data
      part2-002b.aup
      part2-002b_data
      part2-002c.aup
      part2-002c_data
   My-show-part3
      part3-001.aup
      part3-001_data
   My-show-Full-Mix
      Full-Mix-001
      Full-Mix-001b
      Full-Mix-002
