Auto Export-Selected
This read-only archive contains discussions from the Adding Feature forum.
New feature request may be posted to the Adding Feature forum.
Technical support is available via the Help forum.
Post by kozikowski » Tue Jul 22, 2014 4:15 pm
This burns me every couple of months.
I carefully select a small portion of a show and Export it. No, that's not what happens. Audacity insists on exporting the whole show unless I explicitly select Export-Selected.
Since I'm usually in a hurry, it takes a couple of passes before I wake up.
"My export is huge. What the frog is going on...?"
Sometimes the difference is small and I don't catch it.
I know mind reading is a Mac thing, but really. How much mind reading could this take?
Re: Auto Export-Selected
Post by steve » Tue Jul 22, 2014 10:58 pm
kozikowski wrote:I carefully select a small portion of a show and Export it.
How do you do that?
  • "File menu > Export..."
  • Command+Shift+E
kozikowski wrote:Audacity insists on exporting the whole show unless I explicitly select Export-Selected.
(In the voice of jean-luc)
"Computer, save my work.....
NO! Not all of it!"
How about setting a keyboard shortcut for "Export Selection..." and removing the shortcut for "Export...", then as long as you use the keyboard shortcut it will be impossible to accidentally select "Export..."
Post by kozikowski » Wed Jul 23, 2014 12:56 am
File > Export.
Remember when we had that kerfuffle about Applying an Effect to everything as a default unless you had something selected.
Do that here.
Post by steve » Wed Jul 23, 2014 1:10 am
kozikowski wrote:Remember when we had that kerfuffle about Applying an Effect to everything as a default unless you had something selected.
Do that here.
If we counted votes against, I would definitely vote -1 ;)
It may be the Mac way to do what Apple thinks the user is thinking, but the Linux way is to do what the user tells the program to do. If I want to export only the selected part then I'll choose to "Export Selected". I don't expect the program to Export Selected unless I've told it to do that.
If we did have that option, then I'd anticipate a huge wave of complaints that "Audacity only exported a small part of my project".
Post by kozikowski » Thu Jul 24, 2014 7:24 am
That means you're for it.
I did tell it. I carefully selected a portion of the show. Why else would I do that?
Post by kozikowski » Thu Jul 24, 2014 7:25 am
Maybe Export and Export-All.
Post by Gale Andrews » Thu Jul 24, 2014 12:25 pm
kozikowski wrote:I carefully selected a portion of the show. Why else would I do that?
Because you selected the last portion to do a fade out and now you want to export the whole song, not just the fade.
waxcylinder
Post by waxcylinder » Thu Jul 24, 2014 12:41 pm
Im with Steve in being -1 on this.
The two commands are quite clear, certainly in 2.0.6 where they have been clarified to Export Audio and Export Selected Audio
And as Steve has already pointed out - if Export Selected Audio is your preferred MO then you can set a shortcut for it or even re-assign the Ctrl+E to it.
Peter.
Post by steve » Thu Jul 24, 2014 1:41 pm
kozikowski wrote:Maybe Export and Export-All.
So "Export" is a renamed "Export Selected Audio" and "Export-All" is a renamed "Export"?
Doesn't that have exactly the same "problem" of clicking the wrong one?
(with the added confusion that it is non-standard terminology that conflicts with every other application).
Post by Gale Andrews » Fri Jul 25, 2014 1:53 pm
waxcylinder wrote:Im with Steve in being -1 on this.
In case it's not clear I am -1 also. I think there are lots of cases where you want to export all (Export) but preserve the current selection.
I could perhaps see a Preference to hide Export Selected Audio, so that Export exported the selection (if any) or all (if no selection). But given the reluctance to add preferences, I think the Gods would not smile on it. It would be one for our plain text audacity.cfg editor that we don't have yet.
