steve wrote:Gale Andrews wrote:Can you explain more? I don't know what you mean. Have you asked for that before?
Same as the "normal" waveform view, but instead of the vertical scale showing absolute (linear) values, it shows dB values, as in the mock-up below.
It may have been the first thing I ever asked for.
And for someone like me, I have the scale set to -96dB because -60 is not low enough, but I really would prefer something in the -72 dB range.
I'll love to see the "goldie locks" option:
-60 is too small,
-96 is too big,
-72 would be "just right"
I record audiobooks, and my room averages -62 dB when it's set for recording. I like seeing exactly where it is in case there is a fan I forgot, or another noise in the area that is just below the -60 threshold. I currently see those issues on the meter, but I'd rather have the 72 dB range spread over the meter rather than the -96. (I do have the meters pulled larger than the default, but still...)
In other words, if we could have something in between the current options, that would be great, but I understand there may be issues beyond the obvious.
