Improving waveform dB vertical scale
This read-only archive contains discussions from the Adding Feature forum.
New feature request may be posted to the Adding Feature forum.
Technical support is available via the Help forum.
Paul L
Post by Paul L » Mon Jul 21, 2014 7:46 pm
There are only a few choices for the bottom of the scale in preferences. Would there be any special difficulty in letting you choose any dB value within certain bounds?
There are also no gradations for the negative part of the wave.
Re: Improving waveform dB vertical scale
Post by kozikowski » Mon Jul 21, 2014 8:03 pm
I think the negative gradations is an old, valid complaint of mine. It didn't bubble up to the top because I never use Waveform dB and I suspect few other people do, either. It's harder to edit in dB, almost impossible if you are in values higher than 60.
The dB range matches the meters. If it didn't I think you might derive contradictory information. That's bad enough now with the blue waves in percent and the meters in dB.
"How come the sound meters are still flashing, but there aren't any blue waves?"
(... and variations on the above.)
Paul L
Post by Paul L » Mon Jul 21, 2014 8:08 pm
kozikowski wrote:I never use Waveform dB and I suspect few other people do, either. It's harder to edit in dB, almost impossible if you are in values higher than 60.
It is my favorite view for editing voice! I do not understand why you think it is "harder to edit." I like how little crackles are more easily seen, and I like it how drops in volume between syllables become very steep sided.
That is, using a scale of 60. But having some setting between 60 and 96 would be even better.
Post by steve » Mon Jul 21, 2014 8:25 pm
Paul L wrote:There are also no gradations for the negative part of the wave.
That's a long standing complaint, but unfortunately I think it is hard to fix. If you want to have a go then I can show you where it is in the code, but beyond that I get completely lost. It is not easy code.
What I would like is an option for dB on the "normal" linear view (as is more usual in other audio editors), but that's not easy either.
Paul L
Post by Paul L » Mon Jul 21, 2014 8:44 pm
Do you know why I can't choose any lower limit between -60 and -96, Steve? Someone told me it complicates the math, but I don't get why it would.
Paul L
Post by Paul L » Mon Jul 21, 2014 8:46 pm
I guess another good question about views, is why the dB floor or the spectrogram window or window type can't be varied independently among tracks. But of course that means somehow adding controls to tracks.
Post by steve » Mon Jul 21, 2014 9:11 pm
Paul L wrote:Do you know why I can't choose any lower limit between -60 and -96, Steve? Someone told me it complicates the math, but I don't get why it would.
If this is what you mean, then it's rather easy:
Paul L
Post by Paul L » Mon Jul 21, 2014 9:14 pm
Ah, I should get out of 2.0.3 one of these days.
But why discrete choices anyway?
Post by steve » Mon Jul 21, 2014 9:40 pm
Paul L wrote: I should get out of 2.0.3 one of these days.
Paul L wrote:But why discrete choices anyway?
Why not?
Do you want a slider? or text input? or a rotary control?
I don't see that it makes much difference while the control is hidden away in Preferences.
I guess the developer though that half a dozen options was enough.
There is a feature request on the wiki:
Control for Meter/Waveform (dB) display range on the fly instead of in global preferences (2 votes) Cascading menu item "Meter/Waveform dB range > " in the right-click meter menu?
Do you want to vote for that?
Post by steve » Mon Jul 21, 2014 10:08 pm
I agree that the current list of options for dB range has a bit of a gap:
  • 36 dB (shallow range for high-amplitude editing)
  • 48 dB (PCM range of 8 bit samples)
  • 60 dB (PCM range of 10 bit samples)
  • 96 dB (PCM range of 16 bit samples)
  • 120 dB (approximate limit of human hearing)
  • 145 dB (PCM range of 24 bit samples)
In case it is of use to anyone, I've attached a patch that fills that gap to give:
  • 72 dB (PCM range of 12 bit samples)
  • 84 dB (PCM range of 14 bit samples)
dB-Prefs.patch
(1 KiB) Downloaded 60 times
Reason: Fixed type (72 dB is 12-bit range)
