Post
by Audaciouslee » Thu Jan 04, 2018 10:43 pm
Hi, Guys,
Hardware: Thinkpad P51
OS: Ubuntu GNOME 16.04
I tried the suggested "fix" for this by using Terminal with this command:
~$ env PULSE_LATENCY_MSEC=30 audacity
Problem didn't resolve, but I got the following list of messages, that I hope will be helpful:
ALSA lib pcm_dmix.c:1029:(snd_pcm_dmix_open) unable to open slave
ALSA lib pcm.c:2266:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.rear
ALSA lib pcm.c:2266:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.center_lfe
ALSA lib pcm.c:2266:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.side
ALSA lib pcm_route.c:867:(find_matching_chmap) Found no matching channel map
Cannot connect to server socket err = No such file or directory
Cannot connect to server request channel
jack server is not running or cannot be started
JackShmReadWritePtr::~JackShmReadWritePtr - Init not done for 4294967295, skipping unlock
Expression 'stream->playback.pcm' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 4611
14:32:47: Debug: Unknown accel modifier: 'left'
14:32:47: Debug: Unknown accel modifier: 'click/left'
14:32:47: Debug: Unrecognized accel key 'drag', accel string ignored.
14:32:47: Debug: Unrecognized accel key 'click', accel string ignored.
14:32:47: Debug: Unknown accel modifier: 'right'
I'm a linux newbie / recent Windoze convert, and hoping for some help with this.
Thanks very much!
